It's pretty simple to remove, so I'm speculating that it's also pretty easy to add back on. It's held up for the most part by an adhesive (and the weired screw underneath), so I'd imagine it's not a big deal.
I took mine off to wrap the bumper and took the opportunity to replace the screws with stainless steel Phillips head equivalents. Much easier to work with. Home Depot. Metric threads though so limited options in the US.
It's way harder to uninstall. I needed a heat gun to loosen the tape.
You'll need some automotive trim tape - like double sided tape on steroids. Find it on Amazon. The screws don't really do anything and won't hold it without new strips of tape.
The easiest way to remove the tape once the black mounting plate is off is to pull the tape parallel to the surface of the bumper. Think 3M Command strips.
