They finished my service call and I got this on my service report, telling me basically I should read the manual. I thought this was a known Tesla issue. How many others have this problem and we’re blown off by Tesla?
This is total BS. The manual clearly says it is supposed to swing forward. Then you can push it downward (not forward) to make it lay flat.View attachment 575100 My rear left seat does not fold down with the use of the rear hatch switch. I brought it for service for a few minor things with the seat issue my prime concern. At the time of drop off the tech tried to tell me that I just had to push the seat down after using the switch. I said bullshit, they are designed to fold down upon release, just like the right side seat back.
I am waiting for my service center to receive new rear seats. The left pair dropped with the trunk release, but the right seat did not (we could hear a motor whir, but no drop. It has been a couple of months since I picked up the car and noted this (the only fault I could find).
Tell SC to watch their own support videos showing operation of rear seats Model Y Support VideosDid your right seat move at all? My left seat moves about 2-3 inches and then stops.
The left 2/3 dropped down, quite violently. The right side did not move but there was a motor sound from the seat.Did your right seat move at all? My left seat moves about 2-3 inches and then stops.
The middle part (seat) of my Y had a similar problem - it wouldn't fold down by itself, but did make a motor sound when using the switch on it. SC fixed it, some loose cable I think.The left 2/3 dropped down, quite violently. The right side did not move but there was a motor sound from the seat.
What was done to fix it?I had the same problem with the left/center seat. Right seat fell when I pull the switch, but the left one had to be pushed. The delivery person said that it may need to wear in, and I could make a SC if it does not. It was intermittent the few time I used the switch in first month, then I got Tesmainian floor and trunk mats. In vacuuming the floor and trunk carpets to install the mats, I noticed the trunk carpet had a strip of plastic glued to the edge next to the rear seats. The carpet partially separated from the strip next to the left seat. I took a picture, sent to the SC got an appointment, and now it is fine.
Basically they used carpet tape to stick the carpet to the plastic. It looked like the factory used hot glue originally, but the glue dried before the plastic strip was fully mounted, and only half of stuck.What was done to fix it?
