Refresh 2021 front bumper facelift on 2016+?
hi any updates on the fog lights? just finished my rear bumper today now just need front
Reactions: taimurasad
I didn’t know you can order parts with the app. Pretty cool.
Thank you. I’ll try SC as well now. Hope they honor the request.
Sorry guys, they cancel my order because it wasn't compatible.
I'm not in a hurry for the rear diffuser. The hard part is both front and rear tow hook cover are hard to come by and they are very expensive compared to $11 for the rear and maybe cheaper for the front from SC.
Nice rear, lol.
Got picture of the bottom diffuser to show everyone on how you done your mounting?
i did the same exact as the guy had posted worked like a charm here the part we cut and a whole shot of my x
Reactions: Rockwell
There's 3 parts that needed to retrofit the new bumper to work and keep everything original.
1) The hardest part for this bumper to fit perfectly is to cut old center top edges hole clips from old then plastic weld them to the new bumper.
2) Next is to cut the old duct and plastic weld them to the new bumper to make it reach to the duct opening.
3) Reinforcement bar need to cut both end to fit foglights and bottom to fit air duct.
All sensors remove from old with bracket and re-glue to the new bumpet. Fog light still trouble since it's a 3 pins instead of 6 pins.
hey can u show a pic of when u meant with this one? 1) The hardest part for this bumper to fit perfectly is to cut old center top edges hole clips from old then plastic weld them to the new bumper.
Here's the picture. I didn't have a chance to repaint the bumper.
so i have no idea what im looking at but i am sure someone here will attached is supposedly the 2 wire schematics for a 2018 model x fogs and the 2023 model x so the harness pins and everything can anyone figure this out and see a way to re pin the harness to work with the refresh fogs?
  • P2S WIRING DIAGRAM.pdf
  • MX WIRING DIAGRAM.pdf
ok Fellas i disassembled the 2018 fog light can anyone do anything with this and figure out how we can get the 2023 style to work? maybe using the 3 wire fogs instead of the 6 wire ones? i was told that in the 2023 the body control module controls the fogs but in the 2018 they are controlled in the fog light itself im assuming with the whole contraption inside lets get this figured out fellas!!!
the rest of the photos
