Empty tank
MXLR/BLK/Cream/20"/FSD Delivered 6/15/22 Flawless
Same here on and offWeird. It's now gone back to January, delivery info will be available soon. It's going back and forth. very odd.
I think the NEMA 14-50 outlets for a garage is a great solution. Have you ever tried with a 60 amp breaker (and proper wiring #6 I think) that should give you 11.5 Kw? I swear I found one in a campground that had 11.5 output.The NEMA 14-50 adapter no longer comes with the cars. You still get the NEMA 5-15 (household 120V) adapter with the mobile connector, as well as the J1772 adapter. I believe Tesla is encouraging new owners to install Wall Connectors for home charging, but you can still buy the NEMA 14-50 adapter in the on-line store. Personally, I bought the adapter "variety pack" when it was in stock...I have NEMA 14-50 outlets in my garage and I feel kinda naked when I go on a road trip without every adapter I can possibly have.
Bruce.
Can you confirm if the third row seats have LATCH/ISOFIX connectors for car seats?Hi folks,
want to give a quick update on the car. I guess it is similar to the new S where the yoke needs some time to get used to. I thought the build quality was much better than I anticipated. For instance, the front and falcon door handle alignment is very good. There was an instance of disabled air compressor with warning message, but disappears after a hard power off.
I won't say the third row is anywhere close to spacious but the second row can be adjusted forward. In this case if its not for little ones, I feel that the 6-seater may provide a better 3rd row experience because the passengers can at least put their legs in the middle. Also, to fold the 3rd row I first press a button to fold the headset, and then manually fold the body, I was hoping it can be fully automatic given its price range.
Also found it annoyed that we can't seen to zoom in the navigation map. Still can't figure out if the currently offered weather mat is compatible with the 2021 version. Tried reaching out to Tesla but did not get any response yet.
I have gotten several PMs on asking more pictures so I will try to share some later.
Also can you confirm the mileage you're getting with what Wheels 20 or 22'sHi folks,
This probably cannot be said enough... But thank you for coming back to talk with us lowly "Waiters" even though you've graduated to being an "owner" you are, and will forever be Our Hero!Hi folks,
My 2016 MX has the latch system in the third row, so I expect since these seats are essentially the same, that they also have the latch systemAlso can you confirm the mileage you're getting with what Wheels 20 or 22's
Haha yeah just throwing a data point out for my Plaid peeps
I am miserable at math but somehow got to the top eschelons of several corporations and do my own taxes well ahead of the MBAs I know.For your reading pleasure:
Are You A Person Who Needs Even Numbers On The Volume Dial? Turns Out, You're Not Alone
Ever wonder why you prefer to have an even number on the volume dial rather than leaving the TV's sound on, say, 73? While many write this quirk off as a minor OCD habit, our emotional ties to numbers may, in fact, be ingrained in our humanity. In…www.bustle.com
Actually, desktop vs mobile view shows different text.Same here on and off
You're correct. Starting in November 2019 (2020 MX), they removed them apparently due to a new seat being used.I thought I read somewhere that they removed them in the 2020s…. Maybe someone with a newer model can confirm.
Nema 14-50 with Tesla mobile connector limits to 32A, 8KW max, no matter if breaker is 60A or more. To get the 11KW you mention, you need the Wall Charger, which then runs 48A at 11KW.I think the NEMA 14-50 outlets for a garage is a great solution. Have you ever tried with a 60 amp breaker (and proper wiring #6 I think) that should give you 11.5 Kw? I swear I found one in a campground that had 11.5 output.
Six seat, white / white / carbon fiber / 22” turbines / FSD. So, no call (probably because I’m already set for a 6-seat config.Did you order a six seater, and if not, did you get the upgrade call with promises of delivery this year?
Or you can get 40A from the corded connector Tesla sells on Their websiteNema 14-50 with Tesla mobile connector limits to 32A, 8KW max, no matter if breaker is 60A or more. To get the 11KW you mention, you need the Wall Charger, which then runs 48A at 11KW.
Hmmm… looking at the clips from delivery I thought they were white. Sorry it wasn’t “true”That's not true. Sunnyvale's was cream.
Here is the link to the video of one. If that's white to you, then they are all white... yes.Hmmm… looking at the clips from delivery I thought they were white. Sorry it wasn’t “true”
Yeah but then you can only carry 4 (unlucky) passengers. I will be able to carry 5 (lucky) passengers in mine.I am miserable at math but somehow got to the top eschelons of several corporations and do my own taxes well ahead of the MBAs I know.
I have always liked odd numbers just as Nikola Tesla did. You my recall he did all things in multiples of three. Always stayed on the 3,6,9th floor of hotels etc. Plus having lived in Japan where even numbers are unlucky, particularly multiples of 4, I steer away from them. The symbols for deaths is the same as 4. So a “dozen” eggs in Japan has 10 eggs.
So that why I ordered a 5 seater and I could possibly do a 6, maybe in honor of Nikola.
Be curious to know if most folks use 4 gauge or 6 gauge copper wire with the Tesla charger. Seems like either is acceptable. Assume less than 50 ft run. TyNema 14-50 with Tesla mobile connector limits to 32A, 8KW max, no matter if breaker is 60A or more. To get the 11KW you mention, you need the Wall Charger, which then runs 48A at 11KW.
What is the sig of permanent magnet motors?I may have missed the discussion about this (you know, since we're adding 75 pages a week nowadays). But I found this interesting. MX refresh has a 14% lighter battery, 4% lighter curb weight, and 30% more power! (Also front and rear motors are Permanent Magnet - instead of just the rear)
EPA Papers Show How Much Better The New Tesla Model X Is Vs Old
