Thanks for info. I will test it to see if it helps me.The other day I had the noise (same noise as when charging, i..e, a coolant pump most likely) for an hour after driving home (2.4 miles.) I tried opening the door, sitting inside and then leaving. Still humming after an hour. Then I got in and turned off energy saving.10 minutes later (when I checked) it was off. I then turned energy savings back on and the noise was still gone.
My theory is that the car goes to sleep and fails to turn off the pump. With energy saving off, it at least stays awake enough to toggle the pump power.
