Ok I think I got it. Based on the consensus, if you want 19 inch rims with the Replika's,
19x8.5 bore of 64, offset 40
Will this fit the OEM gemini tires?
Do we sill need to buy hub rings and chrome nut installation kits if you get it through canadawheels?
Yes, Just installed mine yesterday and did the 19 X 8.5, 40 offset and 64 hub, the regular, stock 255/45/19s are a perfect fit for that rim. They are hub centric and fit perfectly without hub rings. I re-used the original lug nuts on there and used black, aftermarket caps over the lugnuts.
