Roadster key problem
Discussion in 'Roadster' started by Timothy, Dec 5, 2014.
Tags:
  1. Timothy
    Timothy Driving on Sunshine
    My key had poked a hole in the pocket of my third suit! On our FIAT 500e the metal part of the key bends into the handle so the pointed part is covered when in your pocket and only comes out when you push a button on it. Any solution for the big key on the Roadster? I have a leather case for my house and office keys, and have now started jamming the point of the Roadster key in to it before dropping it into my pocket.
    Has anyone else experienced this problem? Or found a solution?
  2. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Never had a problem with my Roadster key. I don't even bother taking it off the keychain in the winter.
  3. bonnie
    bonnie Oil is for sissies.
    Columbia River Gorge
    I carry a purse.
  4. wiztecy
    wiztecy Active Member
    #4 wiztecy, Dec 5, 2014
    You could pull the Roadster copper key out and make a custom flip mount for it, then have the door fob as a separate dangling entity like a typical fob system off the keychain. Just have to make sure your flip mounting system can take the stresses of the Roadster key on/off turn. It has some good pressure to it. I never had an issue with mine so no need to modify.
    Possibly you could move the guts of the Roadster keyfob to one of these flip key fobs. Well you get my idea:
    flip key | eBay
    DIY how to using a Honda Key:
    DIY: Flip Key with Lots of Pictures!!! - 8th Generation Honda Civic Forum
  5. ggr
    ggr Roadster R80 537, SigS P85 29, M3P 80k
    San Diego, CA
    You could push a bit of rubber tubing over the sharp end.
  6. TOBASH
    TOBASH Member
    New York
    The key comes off of the fob. Drill it with a new hole and that will shorten it up a bit...
    That being said, I would just learn to live with it.
  7. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    The Roadster key is little different from car keys I've been using my entire driving life (43 years of driving) and I've never had a key put a hole in a pants pocket.
  8. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    #8 sethr, Dec 7, 2014
    My Roadster came with 4 keys - two with fobs and two without.
    I always assumed that's how they all came. Is this not the case? (It's 3/4 inch shorter)
  9. wiztecy
    #9 wiztecy, Dec 7, 2014
    Is the glovebox lockable on the 2.x? From what I understand the glovebox only locks when the car is put into Valet Mode and appears to have no keylock.
    The 1.5 Roadsters don't have the box and came with 2 keys both with a FOB attached.
  10. ggr
    San Diego, CA
    Ours is a 2.0, and only came with the two fob keys, no non-fob ones.
  11. wiztecy
    In the pics looks like the copper key is the same length on both, the keyed patterns on both keys appear to be identical so they have the same function. Difference is one set has the fob electronics where the other one is bare. So it just looks like an inexpensive emergency backup set.
    Possibly the second owner (since its a CPO) had a lock company or some non-Tesla supplier make an extra set. I don't see any Tesla markings on the bare set of keys.
  12. Doug_G
    Ottawa, Canada
    In Canada the fob is required in order to start the car.
    A key without fob would only unlock the trunk, and I guess the driver's door too (emergency lock). Might set off the alarm, though.
  13. Chris Lockfort
    Chris Lockfort 2008 Tesla Roadster 1.5 + 2015 Zero SR
    Palo Alto, California, United States
    It sets off the alarm. Found out the hard way when the electronics in one of my key fobs died and I had to unlock that way. You can turn off the alarm semi-immediately though by sticking the fob-less key in the ignition and turning, but the car still will not "start" until you key in your pin code into the touchscreen.
  14. Fabrizio
    Fabrizio Member
    Phoenix, Arizona, USA
    The "fob-less" key is the valet key. When you put the Roadster in valet mode, you give the valet the "fob-less" key so they can't open the trunk or deactivate valet mode with the buttons on the fob, but still start and drive the Roadster.
  15. Doug_G
    Ottawa, Canada
    Makes sense for USA Roadsters. In Canada it won't start without the fob (we have an immobilzer regulation) and entering the PIN will not work. (We do have a valet mode that reduces power... one of the very few things the PIN is good for).
  16. Timothy
    #16 Timothy, Dec 9, 2014
    Great idea. I am just afraid of screwing the key and remote up so I will chicken out. The idea of a rubber tube (condom!) certainly would work. I have taken to stuffing the time of the key into the key holder for my other keys. Not very elegant, but it seems to work. Key for Tesla (6).JPG
    - - - Updated - - -
    That is to say stuffing the 'tip' of my key.....
  17. TOBASH
    TOBASH Member
    New York
    My STRONG suggestion is to remove those pictures of your keys ASAP.
    ANYONE can counterfeit your keys now and break into your house.
    I would re-tool your house locks to accept new keys.
    You should NEVER post images of keys! It is like posting all you bank account information. A thief can now make perfect keys.
    MODS, please delete these pictures for the safety of the poster.
    Best,
    T
  18. spaceballs
    spaceballs Member
    Sammamish
    Have to agree :(
  19. ecarfan
    San Mateo, CA
    (Deleted, posted in error, sorry)
  20. wiztecy
    It looks to me if you button that leather key keeper that the Tesla key would slide right in there and that'd prevent any holes in your pockets.... Problem solved.
    If that doesn't work, punch 2 or 4 holes in your key keeper, then run one or two leather laces through the holes (one leather lace per 2 holes). Next slide the Tesla key through the holes, ensure the leather lace is tight enough to grip the key but not allow the pointy end to poke out.
    If you "edit" your post, there's a delete "radio button" and a delete key that will remove your post.
