YES! YES! YES! Full report to follow. Car will move and it will charge. No alarms!!!!
Beautiful and informative work Jonathan.
Did you use conductive thermal grease to seat your alumina substrates on the
heat sinks as you did for the IGBT-alumina inteface? Or did you you find that just the
pressure of the board was suitable.
The final torquing and potential substrate fracture must have been a bit unnerving.
Thanks for sharing the torque numbers you used.
It must be even more satisfying to drive the roadster than ever before!
Tesla has come back (as expected, but I'm disappointed) with a single option - replace the entire PEM.Unfortunately, my turn.
Car is undrivable after hearing a "pop" and having the dreaded PhaseB Low Side Desat fault (among others).
I'm assuming the PEM is dead - it will go to Tesla this afternoon for diagnosis.
Weighing options:
1) Engage Gruber for a repair/upgrade
2) Remanufactured PEM from Tesla
3) 3.0 battery - trying to work this angle. Since the upgrade comes with a modified PEM, maybe we can sneak this in the $29k cost?
4) Others?
Thoughts?
Do you have the part numbers for the 1.5 PEM? does it suffer from the IGBT insulation failure?BTW those IGBT's specified are for the 2.5...
To answer your question if the 1.5 suffers from these problems - I honestly don't know. Find attached the IGBT's which we believe are used in the 1.5. When you have you PEM open you will have to check however.Do you have the part numbers for the 1.5 PEM? does it suffer from the IGBT insulation failure?
600 Volt, 50 kA
just looked it up this morning![]()
Do you mean the Visium tinted polycarbonate hardtop?BTW: just ordered a visium carbon fiber glas hardtop
