It's only moot in one direction. But yes, I agree it's moot in the direction you stated.The difference is moot, since if it's expensive for the seller, it will also be expensive for the buyer.
At the new Century City Tesla showroom, in the garage where the Tesla parking is, there is a Model S charger, but NOT a Roadster one. I'm just saying...Outside of this thread, I've heard absolutely nothing that would lead me to believe that Tesla will not continue to support the Roadster. What I have seen (since Joost has left) is a decrease in after-market upgrades.
I don't know, if some are being valued as low as the mid $50k now with life left in the battery, by the time they need a new battery, battery replacement at 40k could total the car. Thus, they become 7yr disposables.This is so true. This would help cement the idea that EV's are not throw-away cars that need to be replaced every 5-7 yrs...
Any discussion or insights on this at Teslive?
Elon or Jerome said something would be done for Roadster next year but didn't go into specifics.
Would a lighter pack mess up the driving characteristics (would they need to make the pack a similar weight giving it a higher kWh)?
Doug - to continue your thought process, if they go to the newer cells for the battery pack, could that also open the Roadster to SuperCharger access assuming the wiring harness can be modified? I know that's a lot of "what ifs", but I don't see the original Roadster surviving long term without this access. Just speculating.
I would like to get the the charger from Model S, even limited to 10kW charging with 3-phases speeds up my travel (did 145.000km within 2 1/2 years).
Second is the problem to cool the PEM. I consumed 10 fans (old style), 3 fan with twin rotors (the last replacement was because a bearing defect).
Got now a cage with a metal maze around the twin-rotors.
Only a liquid coold 3-phase PEM ould help.
Third is the motor which easily overheats as well.
Do you think that the battery pack will be compatible with SC?
I agree it would be very cool to have multiple battery options. But it's so much work to do, and there will be so few sold, I suspect we'll get just one middle-of-the-road option. A little lighter, a little cheaper, a little more range.
Everybody at Tesla that I have heard talk about the possibility of DC charging has been negative. It is clearly possible, but it is also clearly a LOT of work, will cost a lot of money, and they don't want to do it for a low-volume car especially given that most owners take a gas car or Model S on long trips.
I like the math of reducing the number of cells by 1/3. Change from 6831 cells to 4554 cells ( that have at least 50% more capacity )
Each brick is reduced from 99 cells down to 66 cells.
If you upgrade a 2200 mAh cell to a 3400 mAh cell then the pack capacity goes up slightly ( from 56 to almost 58kWh ) while the weight of the cells and hardware to mount them, fuse them and connect them comes down by 1/3. The new battery pack could be 250-300 pounds lighter.
If the upgrade was 2200mAh cells to 4000mAh cells then the new pack would be about 67 kWh instead of the old 56.
If Tesla offered a 67kWh pack that was 300 pounds lighter I would start looking for reasons to spend a pile of money to replace my perfectly good pack.
