Roof Bars
I have received the roof bars for my forthcoming M3 delivery.
Has anyone else used them, the fitting to the roof seems straightforward enough.
The bars are very slick and aerodynamic and they have t slots or fitting cycles carriers etc.
The T slots are, however, filled with a rubber strip which seems to compress.
My bike carrier(Thule) has t bolts but the rubber is too deep/tight to allow the T but to slide along the slot, I can hardly budge it or compress the rubber strip.
Has anyone else used the Tesla roof bars that can advise.
Thanks
Thanks
Is this the official Tesla one? Lots of YouTube vids out there. Some folks have cracked their roof pane, so be wary of that!
I would take them along to the car collection and get them to fit them - they don't add much, if anything to drag so sounds like easy to live with if permanently lift in situ.
Stories of roof bars breaking the roof glass either due to over tightening, or glass misalignment problems. Of course, both will be blamed on you and will be at least expensive to fix, if not inconvenient too. There are some threads in main Model 3 area.
I don't want the bars on permanently.
They don't attach to the glass, there are metal clips that clip into a slot below the rubber and glass.
Over tightening the nuts is something to be wary of though soI will use a torque wrench for that, handbook suggests 5-6Nm, which isn't a lot.
My issue is more with the T slot in the actual bars where you normally slide in the T nuts on the carrier.
There is very little space to slide the T nut and the rubber gives too much friction to move them.
Maybe I need a different bike carrier.
View media item 120698
They did take a bit of coaxing..! As it does involve cutting the strip you might hold off until my approach is endorsed by someone else.. However you clearly can't slide the rack brackets in on top of the rubber.
It appears the bars are made by Yakima and they used a strap system to attach bike carriers or you can use a T nut but on their system the T nut is pushed in from above and turned 90 degrees rather than sliding in from the end on Thule bars.
I am going to see if my Thule carriers can be adapted.
Reactions: Cogarch
You can see from these two shots of the roof how much acceptable tolerance there is in the roof glass. One side big gap, other side probably too narrow to get any fixing between glass and bodywork.
Top one drivers side, second one passenger. Both front section of glass.
Thankfully that’s the piece of glass they need to replace for us because of air leak. Hopefully GB staff can do a better job.
Exactly! I use the Tesla roof bars in combination with a Whisper WB200 carrier. You don't have to slide that carrier into the bar, but push it on top of the slide and turn the T nut. By the way, the combination of the Tesla roofbar and this carrier looks great.
Reactions: Cogarch and hmy7k
judging by the fit it does not look like a custom M3 rack at all. looks like a rack for another car that happens to fit and is being sold as an M3 rack for probably double what it sold for before. I say this based on the pads overlapping the glass not fully on the metal (why would you do it that way?) and the clamps looking like they would damage the chrome.
I imagine that winter temperatures make the rubber a bit more resilient than normal so probably needs quite a bit of force ... could be scary!
Oh god, no. Yakima/whisper bar stuff fitted waaay better than that of you have the right application. I don't have pics, but on the old car the for pack followed the contour of the gutter to sub mm prescission. That will go horribly wrong.
I have whisper bars, just waiting for the foot kit to become available, either online or from Tesla parts.
On the original topic... For my t bolts, to assist I have to push them down, then they slide reasonably easily. Much older bars tho, possibly different.
Hello everyone, I’m looking to get a set of Tesla roof bar for my Model 3 as I can't see any other manufactures out there. To be honest I’m pi***d off at having to pay the ridiculous price (assuming £400 going by the US proice) for the Tesla bars however it is what it is I guess.
Anyway, does anyone know where I can buy these from in the UK? Also, seeing above that Thule carriers may not fit?
£430 actually!
Here :Tesla | Vehicle Accessories Model 3
Try not to crack your roof!
Reactions: MrBadger
