Rt 3 to Cape Cod - HW2 Autopilot speed limit?
Discussion in 'New England' started by xsi123, Apr 2, 2017.
  1. xsi123
    xsi123 Member
    MA
    With the latest update 8.1 (17.11.3) that removes the 55mph on highways, anybody knows if Rt 3 is one of the roads that the limit is removed?
    Thanks
  2. xsi123
    xsi123 Member
    MA
    (Answering my own question here)
    Up to Sagamore bridge, there is no limit on the autopilot speed (up to 80mph). After the bridge, you are limited to 35mph
  3. Jurnimon
    Jurnimon Member
    Boston, MA
    So for AP2 Rte. 6 the max is 35 mph even thought the speed limit is 50?
  4. David29
    David29 Supporting Member
    DEDHAM, MA
    Where did the limit change? If I recall correctly, the speed limit on the bridge itself is 40 or 45, so if you were coming from freeway on the mainland, the car should have reduced speed to a maximum of 5 mph over the posted limit, assuming that AP2 works the way AP1 does in that situation.
  5. xsi123
    xsi123 Member
    MA
    I had to Supercharge so I didn't pass the bridge on autopilot (exited before the bridge). When I passed the bridge then autopilot would not activate over 35mph.
    Having said that, this was pre-17.17.4 update. Now, with the new firmware it should not be an issue as AP2 limits are much higher.
