I tend to agree, this is not really a permanent solution for charging an EV. A $200 extension cord is about half the way there to solving this problem the right way.This is a pretty common problem that people have, that is using extension cords instead of doing or hiring electrical work. You think because you have an outlet somewhere that you have a "headstart" towards 240v and can just buy an extension cord 40'. Just hire an electrician.
Here's a suggestion for that. I've done this as have some other people with your setup. If you cut the neutral pin off of your Tesla 14-30 plug with a Dremmel or hacksaw, it can plug directly into your 14-50 extension, and the current will be set automatically without your having to remember to do it. That neutral pin is not connected to anything inside the adapter anyway.For traveling I got a 14-50 extension cord (heavier wire) then attach a 14-50 to 14-30 adapter. I carry a bag full of adapters, all which connect to 14-50. If you go this route, you must remember to set the charging rate in the car appropriately or else you will pop the breaker.
They’re asking to start at a 14-30 dryer plug (well actually they asked about a “15-30” but I’m just assuming that’s a mistake), so we’re talking about 24 amps here.I was going to tell you to make one with instructions, but for 220 at 32 amps 40 feet is too long in my estimation.
12 gauge is in no way adequate or appropriate for this. This is bundled cable being discussed, not separate wire in conduit, so it would generally fall in the 60 degrees C temperature rating, which is rated for only 20A circuits, providing 16A continuous current load. Even if you try to use the 75 degrees C rating level, that is only at 25A circuits for a 20A continuous load. That is still not appropriate for running on a 30A rated circuit with a 24A continuous load. 10 gauge wire would be the correct level for this kind of cord for a 14-30 outlet.Lest people tell you that #12 is under rated, it's ampacity rating is quite adequate for this application at 25ft lengths. Go to #10AWG if you are not comfortable with #12.
ImI sorry, but removing a ground pin is ALWAYS a bad idea.Here's a suggestion for that. I've done this as have some other people with your setup. If you cut the neutral pin off of your Tesla 14-30 plug with a Dremmel or hacksaw, it can plug directly into your 14-50 extension, and the current will be set automatically without your having to remember to do it. That neutral pin is not connected to anything inside the adapter anyway.
It is certainly not ideal. However lots of the non molded plugs that you use to build or repair have the option to leave it out.ImI sorry, but removing a ground pin is ALWAYS a bad idea.
If you or someone else happens to use it for something else, death is quite possible
This is exactly what I do as it gives you more flexibility on types of plugs you can easily use. 14-50, 10-30, 14-30, etc. The cable is a little bit more of a pain to haul around as it's very thick but with a 35ft extension that is basically overbuilt I get almost no voltage drop. As you said though, the big key here is it's up to the user to manually set the charge rate to 80% of the outlet type as you are always using the 14-50 plug on the charger side.
Can you explain to me the difference in electrical terms between a piece of romex in-wall and a properly sized and connected extension cord? If I give you a $1000 Fluke true RMS meter to measure with can you tell the difference if you do not know which is which? Can the car?The safest length for an extension cord in this context is zero.
