So San Jose would permit a stack of 3 powerwalls these days with no bollard?
All the best,
BG
Let me put it this way, that is the system I would design in that city. I won't pretend to know the AHJ 100%, but as drawn, this is a code-compliant installation in my opinion. I do not have the authority to make a more definite statement.
The wild card is jurisdictions are changing their minds constantly. Next week it might be different. An inspector might have a bad day, or not be well informed.
Last month this stacking approval changed in County of San Mateo. I literally had to do the inspection myself and answer every question the fire marshall had. They tried to cancel the permit issued a year ago because "we are supposed to know the code and that 3' was required between the ESS as of July 1 2021." After an hour or so, they performed the final signoff because they agreed we followed the code to the letter. They stamped and approved the UL 9540A testing in that case and our plans which clearly showed the intended field conditions.
The month before, it was Menlo Fire suddenly disallowing the Tesla UL 9540A testing and therefore stacking, so this problem is getting worse. There are fewer bay area AHJ who accept the Tesla UL 9540A testing these days than those that deny it. I have tried to educate people as best I can but a specific few in the fire community won't approve Tesla 9540A testing on a technicality and also are convincing other officials the same.
There are 4 levels of testing in the UL 9540 Standard Cell - Module - Unit - Installation
If your Li-ion battery could pass the cell or module level testing, then no unit level testing is needed since no flammable gasses would have escaped. This ESS could be marked "For use in residential dwelling units" (AKA the Unicorn Mark) and would not be location restricted. You could put it in your kids bedroom right over your headboard or in your kitchen as far as the fire code is concerned.
The Santa Clara County fire service pushback is that "Cell and Module level data was not provided by Tesla" but unless you are aiming for a unicorn mark (or possibly indoor installations where the buildup and composition of flammable gasses is a concern) that data has little relevance. Nobody is installing raw Tesla powerwall cell or modules in their garage since the code requires UL 9540 listed systems.
The data that matters is the unit-level data, and that data shows that a powerwall that is pushed into thermal runaway in the test lab will not propagate to adjacent surfaces, nor be hot enough to ignite dry wood from heat flux. If the PW unit had some installation restrictions, such as not being allowed on an untreated wood siding wall or under a wooden overhang or eave, this would come up in the installation level testing and be noted in the report and installation manual as a restriction.
Other ESS manufacturers are primarily using iron phosphate, and are releasing media all about how safe their iron phosphate chemistry is, compared to the dangerous NMC Tesla chemistry. This plays right into the fears of the fire service, and so far Tesla hasn't been very successful in convincing anyone otherwise.
