JRP3
Hyperactive Member
Quaife - Quaife made a LSD for the Model S, they'd probably build one for the soon to be higher volume 3.
That's good to here!Quaife - Quaife made a LSD for the Model S, they'd probably build one for the soon to be higher volume 3.
IIRC with Torsen type LSD differentials, this won't work. Torque transfer only occurs under load. It puzzled me at first, but it worked.Yeah. I wasn't sure if he jacked up the rear end and spun the wheel to check if it was open or limited since I last watched his videos. Limited has more wearable parts, so I'm guessing open.
Because a) it has air suspension and b) it doesn't have adjustable dampers.How do you know it won’t have M3 level handling? My guess is that it will.
Not possible. Tesla can make radiator 3x bigger but air intake scoop has cross section fixed to very modest size. This is the limiting factor, not cooling system.I have faith that Tesla will have designed the Model 3P to have a large enough cooling system.
What do you think the intake cross section of this V8 powered ICE is?Not possible. Tesla can make radiator 3x bigger but air intake scoop has cross section fixed to very modest size.
I mean it's possible for them to make the air dam bigger. Possible but not likely. No one here knows how good the current cooling system is because the only data point is four laps at a moderate pace before the brakes failed. And it was on a very cold day.Because a) it has air suspension and b) it doesn't have adjustable dampers.
Im sure @mattcrowley is an awesome driver but I doubt he was going full speed on his first four laps in a car he had never driven at the track. "No brakes left after the 4th lap." I also doubt he was pushing it too hard after the brakes went out. Also the track was wet.No, it was 9 laps at a pretty good pace.
All D's will be P's?! And miss out on the extra $20K for the P?
You know there is exactly no chance of D==P being true!
For any normal driver, Tesla already cleans their clocks. And so you see more Model S sold than BMW Series 7 and 8s.I guess we'll see. Performance will definitely be dual motors only. The Model S is pretty useless on a track, the BMW M3 works pretty well. If Tesla is serious about cooling and brakes it could give BMW a challenge.
It's a good time no doubt, close to the EV production record set by the Bolt (which had cooling problems). It's a long way from an M3 though which can do that track in about 1:40. Regen will make almost no difference, braking from 100mph takes a crazy amount of power.Have you watched the video or looked at his data? I never said he was going full speed...
Yep top speed was on lap 4, he did slow down a bit for the remaining 5 laps...
His best time at that track is 1:41.9 in his GT4. His best lap in the Model 3 was 1:57.50. Doesn't seem bad for his first time out with poor track conditions...
I would love to see how he would do, and what the brakes would look like, if he tried again but with regen set to standard. (I would even put money toward another brake job.)
This thread is about track performance though. As a street car Teslas are awesome. I don't think the performance Model 3 will be able to challenge the BMW M3 at the track because I don't think Tesla has shown any interest designing a car to do so. There have been plenty of revisions of the Model S and they haven't improved the cooling or added the ability to disable stability control. It is promising that they were testing the performance model at the track though!For any normal driver, Tesla already cleans their clocks. And so you see more Model S sold than BMW Series 7 and 8s.
And I suspect Tesla collects more $ dollars as well than BMW collects on their Series 7 and 8s combined.
I think the only metric BMW can win is miles driven before needing a refueling and top speed, right?
They really shouldn’t care as long as they can keep the margins. The 3 is supposed to be designed for lower cost production. It may have higher margins.I totally agree with what you're saying, it just seems like an odd move from Tesla's part, like product cannibalization - exactly what they said they wouldn't do with the 3.
I'm just saying it's a little early to say that power limiting won't be a problem on repeated fast laps in warm weather.
I don't have any hard data but I think that they have improved the cooling, but there is only so much they can do with an AC induction motor...
