AZ Desert Driver
Rare combination
Thanks ...1.1 g just seems too much. 850 hp is not enough to accelerate? Nothing calculated, just gut feel. Thanks for the calculations - and explanations. My feelings have been trumped by science.
How quickly? Hasn't happened to me for the 2012 P85 or the 2014 P85D yet.Eventually the novelty wears off and you use it less and less.
I have spent my career as an engineer - specializing in material science. Many degrees, many hours in research labs. Your calculations SOUND fully reasonable. I've never been exposed to that flavor of physics. Can you illuminate how you got to these amazing figures? i.e. - how 1.1 g can be obtained - even with sticky tires. How 854 hp can't accelerate faster, just increase top speed. I am not doubting you. I've just never been exposed to these types of calculations.
thanks all- for the clarifying formulas. now that you have revealed, they seem obvious.Just to add some additional information, for those interested how fast an EV (one fixed gear) with a certain power and friction coefficient could accelerate.
The discussed problem was the simplest one, we reach the point of maximum power at 60mph, but we could also assume that we have a friction coefficient of 1.1, but only 500kW. That would be a bit more complicated, but sill solvable.
To get the maximum acceleration, we need to use all the force we can, without slipping.
So we just calculate the speed until we can do that. In our example, 500kW, 2.2 tons and 1.1g, v = 500 kW /( 2200kg * 1.1*9.81m/s^2)
= 21.06 m/s
Now we need the time until we get there t = 21.06 m/s / (1.1 * 9.81 m/s^2) = 1.95s
After we get the time to the point of maximum acceleration, it gets a bit tricky and there are multiple solutions. In my opinion the easies way is using the correlation between energy and power. Power is energy d/dt. In our case we just assume that the power stays constant after that point and we don't have to dial back because of increased proximity and skin effect losses.
So we just need the additional energy needed, to have a car moving at 60mph, or 26.82 m/s , over a car moving at 21.06 m/s.
W = {1/2 * m * (Vend)^2} - {1/2 * m * (Vstart)^2} = 0.5 * 2,200kg * (Vend^2 - Vstart^2) = 303kJ
Now we divide that by 500kW and we get 0.61 seconds. We add both times and we get to 2.558s
So not really a lot less, although we reduced our power by about 25%. If we reduce power by 50%, to 319kW we still get a pretty decent 3.1 seconds. Even with just 200hp, less than a quarter of our original calculation, we still end up with less than 5.6 seconds. If we, on the other hand increase our friction coefficient against infinity, we still can't get less than 5.27 seconds with 200hp. Because thats the time it takes to "fill up" the car's energy from 0 to 791MJ with 150kW.
In realty its always a bit lower, since there are also rotation masses, especially the wheels, which also take up lots of energy to speed up and of course some reaction time, be it your brains switching frequency, or that of a microcontiolller, IGB, CPU or something like that.
You can easily do these calculations with excel, its interesting to see what effect power and friction have on 0-60, 0-100, or 0-155mph times. If you want, cow can also add aerodynamic drag, which I left out, or a reducing power curve.
Whats next? the P100D+ And i bet the 0-60 is going to be about 2.3 Seconds and after that an even faster car! with a 0-60 of about 1.0 Second is that when Tesla's gonna stop b/c the Lamborghini and Bugatti might get jealous..... but heck they probably are already jealous!!
Have you ever actually been in one of these situations without Ludicrous enabled and found the "basic" 90D power insufficient?You find yourself in the wrong lane, you didn't see the oncoming car when pulling out, etc.
How can the 5-60 time be greater than the 0-60 time?
