SpeedyEddy
looking at the minute wicks: this was the bottom!
For me, I see NO, ZERO, NUL, KEIN probability. My base case would be to A) remove the anomaly of Jan 2023 from the calculus, and then B) create a double bottom of the MAR-MAY 2023 period (with some upward adjustment in terminal price).. only THEN do we have a solid very strong and lasting base to build upon to retest new near term highs and ultimately new ATH (not adjusted for inflation - which would be a LOT since Dec‘21)@dl003 @tivoboy @SpeedyEddy
What do you think of the possibility that the same pattern from Jan 2023-May2023 (left circle) is unfolding now between July 2023-Feb 2024 (right circle) with equivalent extension if we break the green line? Looks eerily similar in formation albeit a bit wider. If you look at each wedge it’s almost identical. If we keep the same % run up, by February we’d be at $381.20. And then dump down to $200-180's as previously expected mid-Feb.
The overall timeframe for that 2nd base would be Q1’24 into Q2’24, most likely in Q1’24 though all things considered. Deteriorating macro, lasting fed policy impacts, housing retracement, I have to stop there.
If you/one believes that any further downside is limited, and we’re going to ramp to near ATH by end of Q1’24 into Q2’24, then those calls at ~ 330-350 should be pretty darn cheap at this point.
Breaking out has always been a possibility once we bounced from 194, but 381 by Feb? Nope. To shamelessly quote myself:@dl003 @tivoboy @SpeedyEddy
supposed to wait, doggyreenter for 12/8 +245C to ride the bounce if this is base. Good luck guys
edit - enter since Macro start turning green and SP was bouncing between 233-245 for past 15 minutes.
Don't follow as this is purely doggy sense.....
Bought puts (3rd roundtrip):
25x BPS -220/+225 12/15 @$1.00
Also after a few roundtrips today, STO accompanying synthetic shorts:
10x -C270 12/15 @1.40
10x -C275 12/15 @1.02
10x -C280 12/15 @0.76
