Week like this have you thought about closing the 540s early? Or is the premium so low it’s not a bother ?I'm back in as well - 740cc for this Friday. After all - these are I-dare-you cc .
I'll have to look into updating my BPS as well. The 540/640s are doing really well today - raises the possibility of an early close. But I have other things to do so it is time to let them simmer a bit longer - maybe late morning it'll be time to close. THey're ahead 60% at this point and worth about $2.
Good catch - those got closed yesterday in the move up, with the 560/660s replacing them today.Week like this have you thought about closing the 540s early? Or is the premium so low it’s not a bother ?
This is where spreads start tweaking my brain a bit. Given equal short leg strikes, wouldn't a tighter spread with less risk (lower max loss) be less leverage, not more, compared to a wider spread?I also now think of the spread size as the amount of leverage I'm putting into a position, with smaller spread sizes equating to higher levels of leverage.
The observations that lead to this point of view:This is where spreads start tweaking my brain a bit. Given equal short leg strikes, wouldn't a tighter spread with less risk (lower max loss) be less leverage, not more, compared to a wider spread?
Cash secured puts are necessarily not naked. And for naked puts, with portfolio margin, it is not the full amount though it varies I believe based on both your portfolio and strikes. For me it tends to be about 1/3 to 1/5 of the full amount.Or the real kicker - if you compare the margin required for a put spread to a naked put (same principle applies to calls, but puts are easier to see), then a $600 strike naked put needs $60k to be fully cash secured.
Yeah - I use the $60k cash secured put as the point of comparison as its easiest to see. As far as I know the margin reservation for a $100 spread is $10k - there isn't variation on that point, whether portfolio margin or not.Cash secured puts are necessarily not naked. And for naked puts, with portfolio margin, it is not the full amount though it varies I believe based on both your portfolio and strikes. For me it tends to be about 1/3 to 1/5 of the full amount.
Oh for sure, I just wanted to point out that naked puts can still allow for more leverage if you have portfolio margin, as it takes into consideration that the stock will probably not just go to 0, treating it more like a spreadYeah - I use the $60k cash secured put as the point of comparison as its easiest to see. As far as I know the margin reservation for a $100 spread is $10k - there isn't variation on that point, whether portfolio margin or not.
But at least for me, even if there was less margin being reserved, my own objectives would keep me from using that extra margin. I'm already adding a lot of leverage doing things the way I'm doing them (lot of leverage for me). There is a lot more leverage available should I want to use it, but income orientation says hands off
In particular, my leverage in action comes from selling put spreads instead of selling puts, and selling calls against purchased leaps (calendar spreads) instead of shares.
To keep the leverage under control on the call side (while still using some leverage) I've been targeting around 2 - maybe 3 - leaps per 100 shares they are replacing. I get leveraged exposure to upside moves from the leaps, and the ability to sell 2-3x as many lcc's in the meantime.
The pattern I've started using last week and continuing into this week can, I think, be summed up as:
1) open CC / lcc into a move up (like yesterday). Look at closing put spreads at the same time (close put spread into a move up)
2) close CC / lcc into a move down (like today). Look at opening put spreads at the same time.
Actually in both cases it's look into the position profit changes and see if they've moved enough to be worthwhile.. So far in the last week or so, each time I look at making the change, the profit % has been high enough that I'm taking off the winnings and putting on new positions. Profit % has been 40-90% - mostly in the 50-60% range, for 1-3 day positions.
To make this work it mostly simplifies even further - if I close something today, then the soonest I open its replacement is tomorrow. Close winning positions aggressively (say 50% plus).
I'm also not sweating trying to hit high/low points during the day - just make the move when it makes sense at that moment. And so far I'm also getting awfully close to peaks and valleys, though I consider that to be by accident.
The entry strikes are chosen using my previous patterns. Pretty aggressive on the call side in the .5-1.5 week expiration range, at least for now; and pretty conservative on the put side (around .10-.15 delta, 1.5-2.5 week expirations).
Without intending to be pedantic, the reservation in that case is 10k - total premium, which is not important for the sake of this discussion. I only mention it because I checked just to be sure.Yeah - I use the $60k cash secured put as the point of comparison as its easiest to see. As far as I know the margin reservation for a $100 spread is $10k - there isn't variation on that point, whether portfolio margin or not.
Yes it is, and no I'm not. The wash sales seems to have been resolved for options to mean identical kind / strike / expiration. It also seems to be the case that the only trades I've been flagged on for wash sales were same day, but I think this is more likely a function of slightly different strikes. I.e. selling a 640 call yesterday, buying it back today, and selling a 650 call today, doesn't trigger wash sales because the 650 and 640 are different.Is this trading taking place in a taxable account? You must be getting whacked on wash sales.
I've noticed a similar dynamic in my taxable account, where the margin affect seems to be lower than the margin I calculate. I still use my own calculation as its more conservative, within a larger context of using leverage to juice returns.Actually I just checked out a silly BPS of -600/+400 and the buying power effect is only -17.4k vs the -19.9k max loss, so I don't know if portfolio margin is causing that effect, but it also is not likely to matter
Portfolio Margin is a risk based approach. If we wake up tomorrow and TSLA drops 10%, it will change quickly.Actually I just checked out a silly BPS of -600/+400 and the buying power effect is only -17.4k vs the -19.9k max loss, so I don't know if portfolio margin is causing that effect, but it also is not likely to matter
i think he meant more time to digest all news & extrapolate premarket to i.e. prepare for a 15:30-15:45-dipWhat do you learn from the pre-market? I can’t find any patterns.
I did manage, by accident, to get the pattern day trader flag set on my account. I'd rather it wasn't there, but so far it doesn't seem to affect anything.
I WILL get whacked at tax time. I'm looking for options / choices to minimize the whack (such as a charitable remainder trust, but this conversation is for another thread), but its also a first world problem. The only way to pay a 50% marginal tax rate is to earn enough to get into that bracket, and that takes a lot of earning (somewhere around $600k). First world problems are the very best.
The other thing about wash sales - a trade flagged for a wash sale just moves its loss into the replacement position. At mid year like now I suppose I could use that to influence quarterly estimated tax payments, but I'm already doing those based on the safe harbor rule, so it doesn't matter this year. It'll all have come out in the wash by end of the tax year and make no difference (as I understand the wash sale rules).
Actually - the money that I'm living on for most of the next decade is happening in a taxable account. I just think of the profits as similar to the paycheck I was receiving previously. I was taxed on that, and it was getting to be a non-trivial amount. I'll get taxed on these earnings.
I'm also doing these trades in retirement accounts. Usually by exactly copying the positions - my intent here, even though I'll probably leave some gains on the table relative to buy and hold, is a larger pool within which to learn from, and be that much more confident in the approach over a 20-50 year (a guy can dream, and exercise ) window of time.
Date STO | Expires | Trade | Strike | SP | Delta | Proceeds | N | Total |
Previous Month | ||||||||
7/23 | 7/30 | P | 600 | 630 | 0.2 | $970 | 12 | $11,640 |
7/23 | 7/30 | P | 615 | 640 | 0.3 | $1,370 | 7 | $9,590 |
Total | $21,230 | |||||||
Current Month | ||||||||
8/3 | 8/6 | P | 680 | 710 | 0.2 | $370 | 10 | $3,700 |
8/3 | 8/6 | P | 690 | 710 | 0.3 | $580 | 5 | $2,900 |
7/30 | 8/6 | C | 750 | 695 | 0.13 | $288 | 5 | $1,440 |
Total | $8,040 |
Well that would be the IV crush after earnings.Well, I have much to learn. I've gone from my best week to what will likely be my worst week running my version of the wheel.
Date STO Expires Trade Strike SP Delta Proceeds N Total Previous Month 7/23 7/30 P 600 630 0.2 $970 12 $11,640 7/23 7/30 P 615 640 0.3 $1,370 7 $9,590 Total $21,230 Current Month 8/3 8/6 P 680 710 0.2 $370 10 $3,700 8/3 8/6 P 690 710 0.3 $580 5 $2,900 7/30 8/6 C 750 695 0.13 $288 5 $1,440 Total $8,040
7/30 was so green I did not STO any puts but STO my first calls in a few weeks. 8/3 was red'sh so STO some puts but I have very little enthusiasm for this week. Would have done much better to STO 7/30.
Hmmm, $8k is your worst week? I’ll take some of that.Well, I have much to learn. I've gone from my best week to what will likely be my worst week running my version of the wheel.
Option | Number | Premium | Revenue | MM Impact | MM/$ Revenue |
Iron Condor | |||||
650/680 740/770 | 32 | $3.75 | $12,000 | $102,976 | 11.7% |
Bull Put Spread | |||||
650/680 | 28 | $1.80 | $5,040 | $100,452 | 5.0% |
Put | |||||
680 | 2.3 | $2.60 | $598 | $100,277 | 0.6% |
Strangle | |||||
680 740 | 2.4 | $5.15 | $1,236 | $103,303 | 1.2% |
Call Spread + BPS | |||||
740/770 | 272 | $1.94 | $52,768 | -$100,368 | -52.6% |
Sub-Total | 300 | $3.74 | $57,808 | $84 | 68819.0% |
