Just spotted this on Amazon and wonder is this is any good.
https://www.amazon.co.uk/Portable-External-Storage-Desktop-Chromebook/dp/B07GKJMQ1N
or this
https://www.amazon.co.uk/Seagate-Expansion-Portable-PlayStation-STEA1000400/dp/B07DQ5ZH1D
As already mentioned these are HDDs meaning physical spinning disk. No issues regarding failure, but the power consumption to keep the disk spinning is a lot more than an SSD. HDDs save power by having a cache and stopping the spin, which is no good for something that is constantly writing (like a dashcam).
HDDs typically use around 4W while in use and 3W while idle - you would need to disconnect this if you leave it in the car or it will feed from your battery.
SSD I linked uses 2.8W while active and 0.05W while idle - wds240g2g0b
Some math wizard can calculate how much range that is per hour...
Second point is you are paying more for the enclosure and manufacturing process than the actual facility (storage space). Meaning you pay a lot for the case the HDD comes in.
