Separate wheels or seasonal tire swap?
ochompsky
87
63
md
So I have a 2020 P3D. I got the PILOT ALPIN PA4 N-SPEC as my winter tires. So far, i've had the tires swapped twice, both times using mobile services.
  • The first swap, they really struggled with the swap. They said low profile tires are difficult to do. They also scratched up one of the rims, it wasn't too bad but noticeable. (it was pretty expensive, $250 for the swap).
  • The second swap, I used Tesla themselves to do the swap. They actually use roadside service to do it, since mobile doesn't have the equipment for tire swaps. The cost was about the same (~250%) but this guy really ****ed up one of my rims. He very slightly comped the service but didn't come close to the $100 cost of repairing it.
So now before winter comes, im wondering what to do. Is it hard to do tire swaps on low profile tires, are scratches just the nature of it? Or am I just having bad luck on tire places?
I'm debating just getting another set of wheels but my problem is also that the Alpin tires are pretty large, im assuming I would need 20 inch rims to accomodate them, so im looking at $2k+. I would honestly prefer 18 inch rims in the winter for cost, comfort and range but now i've already bought these tires and they are pretty new.
What should I do? Get new tires + 18 inch rims, get new rims only for the current tires, or just continue doing the swaps until I find a better shop to do them?
Aug 7, 2020
793
1,634
Find a better shop but anytime you change tires there’s a risk for wheel damage. I’d get a set of 18” wheels for winter if I needed to do so.
Stanwood Steve
2018 Performance Model 3
Mar 30, 2019
136
183
Stanwood, WA
I have the 20" rims and bought the same set of winter tires. I elected to buy a second set of rims through EV Wheels Direct (see photo at left), and I just take off the summer tires in early October, and replace them with the winter tires/wheels. I use this as a chance to ensure proper rotation, labeling the new position of the tires I took off so I know what position to install them in next Spring. I have 60,000 miles on the car now, and I'm still using the original summer and winter tires. They're each on for about half the year. Works well for me.
duanra
1,310
810
Montreal
250$ is crazy for a swap.
In Montréal Canada, I have a mobile service company who does it without damage for 90 Canadian Dollars.
DMan918
106
64
Algonquin IL
If you are going to swap, you need to have two sets of rims, and just swap the rim/tire combo. Swapping two sets between one set of rims is just craziness. If you can sell your winter tires at a reasonable price, I would do that and get 18s (or 19s) for winter.
Reactions: THXULTRA
THXULTRA
408
304
Chicago
Going to need winter tires for my performance also. Planning on getting a 18inch set of wheels and tires from T-Sportline. 18s will give you a bit better range, save you some money and have a bit more tire for pot holes.
Reactions: DMan918
ochompsky
87
63
md
thanks for the info. will the tires above fit this sit of rims?
eman2021
21
38
SLC, UT
If you have the cash then the answer is undoubtedly to purchase a separate set of wheels/tires. IMO it's the only way to go. Swapping tires on an off is only asking for damage to the wheels or tires. That's my 2 cents.
Reactions: Skione65
Gimmethecash
355
393
Pasadena, CA
Find yourself a good tire shop that charges half what you’re paying and doesn’t F up your wheels like total amateurs & give lame excuses like saying low profile wheels are too hard for them and their lack of basic skills to swap. And buy another set of wheels.
HaroldC
38
30
Westchester, NY
I would second this. Every time you mount and dismount tires, you are risking damage to the rims. Even the most experienced mechanic will slip up on the steel pry bar and mar the finish on the rim. It only takes less than half and hour to perform the swap and that's without power tools and just a basic jack.
Reactions: eman2021
