Shoot -- my brand new model 3 doesn't have enough ground clearance!
Discussion in 'Model 3: Driving Dynamics' started by markusg, Nov 30, 2019.
  1. DrtyJrze
    DrtyJrze Member
    What does that have to do with the discussion?
    OP, glad you found a solution.
  2. Sclew
    Sclew Member
    NYC
    Is an air suspension within your spending range? Airtekk, airlift, etc brand. You’d jack up going in and out of the garage. Then stock or lowered height for regular driving, which helps with efficiency than driving lifted all the time.
  3. markusg
    markusg Member
    San Francisco
    Probably more than I need, honestly. I may revise my opinion after getting the lift kit installed, though.
  4. boriszima
    boriszima Member
    Los Angeles
    I see your issue from the photos OP. You can’t even approach it from slant, tight spot right into garage. I hope lift kit works out for you and congrats
  5. markusg
    markusg Member
    San Francisco
    Thanks - I’m fairly confident it will. I’ll let everyone know how it goes.
  6. Big Dog
    Big Dog Active Member
    Irvine, CA
    Nah, the garage alone is $1.5M. :p
    But seriously hope the risers work for you.
  7. brkaus
    brkaus Well-Known Member
    Austin, TX
  8. mrjrkingston
    mrjrkingston New Member
    @OP - did you ever install the MPP lift kit?
    I’m curious what the impact on range is versus stock height
  9. markusg
    markusg Member
    San Francisco
    Decided to just stick with the plywood so can’t speak to the lift kit. Sorry!
  10. MountainPass
    MountainPass Vendor
    Toronto, Canada
    On the Y the range difference is negligible, but on the 3 which starts off closer to the ground, I would expect 5-10% impact on efficiency based on average speed!
  11. bl187
    bl187 New Member
    Greece
    this setup really helped me. 7cm lift C4EA6158-BE45-49A5-A3F2-8F0CE316BE26.jpeg
  12. KyleM3
    KyleM3 Member
    PA
    Google “Curb Ramps”, might solve your issue.
  13. juicychus
    juicychus New Member
    Wednesday
    upper left
    this is exactly what i need. where did you find these?
  14. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    Would backing in work?
