jesselivenomore
We haven't even climbed up *as fast as* we fell down. the last time we closed above 200 it was 13 trading days to the bottom. It has been 16 trading days from that bottom to return and close above 200 again. If there was to be a squeeze you would see a departure from the speed of the ups and downs, this is simply a recovery from a dramatically oversold stock that lost 50% of its value in a matter of 2-2.5 months. We will be lucky to return back to those levels in the same time span (and with the macro market holding out positive for now, and the Model X reviews and deliveries finally happening in large enough quantities to matter, this might actually be possible).
From the 240+ close it was 27 trading days, let's see if we can get back to 240 in the next 11 trading days. My guess? If we continue to go at the 23% slower rising pace of what it took to fall, the return to 240 won't happen until 33 trading days from the bottom, which means that we have another 17 days left to get back to 240 which puts it around Mar 29th. That actually makes sense given that we will be building up to the Model 3 reveal and would not be surprised to see us right around 240 just before that happens.
Really good stuff. In essence you are measuring momentum by counting days. If the rally mirrors the decline - it is the definition of a V-bottom. This is what led me to change my stance from buying dips to buying rally(above 220 on heavy volume). Because a completion of the V-bottom(as we keep climbing higher) would be bullish, where a failure of the V-bottom would be bearish(if we go back below 180 I am not buying). Obviously investors would/should play it differently than me.
