It takes about 0.5 kWh to heat a gallon of water 50CWould that really cool the garage? A heat pump is basically just an AC that sends waste heat into the water instead of pushing it outside. So unless you used a LOT of hot water it just doesn’t seem like it would run enough to actually cool the garage.
It would not surprise me if Daniel uses 30 gallons of hot water a day, so ~ 15 kWh of heat transfer
Brah, crack your garage door about a foot. If you have a free wall space, you can have an exhaust fan installed for a couple hundred dollars. I'm in the same outrigger as you. I also have a side access door I leave cracked open about 2 feet. It does help keep the temp below 90. Though, overheat protection is on, I don't want the car sapping juice to keep it cool.It gets hot here on Maui. My house is air conditioned (for free, via solar) but there are no A/C vents into the garage, and yesterday afternoon I measured the temp (with an infrared thermometer gun) at 90° F.
I could get a little cool air in if I left the door to the garage open, letting some hot air into the house. Don't really want to if I don't have to. I could open the big garage door for a half an hour in the early morning before sunrise when the outside temperature is in the middle 70's. But I really don't want to do that. I'm in a good neighborhood, but still... Or I could spend a bundle and get some A/C into the garage by diverting a vent or installing a small A/C unit.
My question: Is 90° F too hot for the car? Obviously, there's no sun on the car when it's in the garage. I'd rather not have to do anything, but when I go into the garage in the afternoon, it's like an oven. (Well, not literally, but you know what I mean.)
P.S. There are places that get a lot hotter than here. We don't get anything like as hot as Phoenix or Las Vegas. But still, it feels sweltering in the afternoon. (Worth it, though, to be able to go out paddling a canoe or kayak on the warm, flat ocean in the morning.)
I am neither an engineer or an HVAC person so I can only give a general answer you should treat with some amount of skepticism:What's that work out to with regard to cooling a two car garage that's 90+? How much heat transfer would be required to cool that much space to even say 80 degrees?
Ouch.I’ve seen my internal cabin temp get in the 160’s regularly.
At first I thought this was a joke because I can't imagine what car company would design a car that can't stand more heat than a human. But I see it seems a serious question. I'd think that if you can take 90 F degrees, then so can your car. Where I grew up, this was a cooling trend
I stand corrected.I cannot imagine what gave you the idea I would use 30 gallons of hot water a day.
I stand corrected.
This study says 60 gallons/day for a household of 4. A single person would use more than 15 since consumption is non-linear as the household size increases.
I remembered that you are a single person household. Mostly I was thinking that a snow-bird constitution would shower a lot in a hot and sticky (humid) climate.I see. You assumed a two-person household. Sadly, I'm only me. Here's another factor: I suspect that the average woman washes clothes far more often than I do. Thus, being a single man, my water use for laundry is probably far below the average. And being in Hawai'i, I probably use fewer clothes, and the national average includes some percentage of people with top-loaders, which use a lot more water than a front-loader.
Thus my estimate of 5 to 10 gallons per day.
And since this came up in the context of using a heat pump to cool the garage while heating the water, note that here in Kihei, the temperature of the incoming "cold" water is actually lukewarm. The water from my cold tap is too warm to drink comfortably. I have to mix in some refrigerated water to make it drinkable. Thus heating my hot water requires far less energy than it did, say, in Spokane, where I used to live, or North Dakota, where I lived before that. So a heat pump would cool my garage even less.
So it's a good thing I don't need to cool my garage after all.
IIRC most shower heads are in the 2-3 gallons a minute range. You can buy more frugal varietiesmy showers are brief
Here’s my set up just outside Sacramento, Ca. Hot here also, fan makes a bit of noise, so don’t run it very long, but does adjust to come on when it hits pre determined heat...also shuts itself off by the same thermostat control...+1
Lately, here in Vegas, my garage has been at 108° when I go to bed and stays that hot until I open it in the morning when the outside air has cooled down to 90°. I’ve been thinking about adding a ventilation fan that will exchange the inside air for outside air once the outside air cools down. I’m not sure if such a differential thermostat exists commercially, but here’s a link to a DIY method: http://blog.uvm.edu/cwcallah/files/2016/01/Outside-Air-Exchange.pdf
