Something like ludicrous modes max battery option.It does heat the pack while supercharging... it just takes a lot of time to warm it up. Tesla could improve this by giving us a manual pack heating option that could be activated well in advance of arriving at a supercharger.
If the internets is to be believed the dedicated pack heater in the S/X only outputs 6 kW of heat, whereas the Model 3 motors can supposedly produce ~5 kW of heat. Realistically it takes a lot of heat to warm up ~1000 pounds of battery quickly. It is why Bjorn said it was better/faster to hammer the throttle than it was to wait on the battery heater to get higher supercharging rates.No & Yes. Sure, they could use better set points or control, but I disagree wholeheartedly in your statement that you don't think the heating method is also a big problem. It really is less effective at generating much heat quickly.
So there you go--the method of heating is the problem.
Heh, you left out the main factor of what they were trying to strike a balance between. They were trying to go cheaper. I'm sure they knew that the Model 3 heating methods were going to be less effective, but probably thought it was good enough. And sometimes for some people in some temperatures, it is, but in other cold places, it isn't.
I'm pretty certain it is already doing that. While it's sitting on a Supercharger and has access to virtually unlimited power levels, that would be the time when it would be using that power to run that motor-heating-the-battery method. The fact that it takes so long for charging speeds to climb upward seems like the most clear evidence that it just doesn't generate heat as fast as the S/X battery heater.
This is something I'm still skeptical of about this method of heating with the motor. I don't know if it can do that. The method of heating using the motor needs to run current through the motor windings, and obviously it can do this when the car is parked. Keeping the motor locked and not moving can be providing extra resistance to the current in those wires because of the magnetic fields, so generating extra heat. But when the car is driving and needs to use those windings in it's particular directions and frequencies to rotate it at the speeds the driver is controlling, I am not sure it can also use those wires at the same time for generating extra heat.
So this is where I see one of the possible downsides to this Model 3 method. I'm not sure it can create any extra heat beyond the waste from operation while the car is driving. But certainly it can do it while parked, and there definitely should be a software control made available that could let owners turn it on.
If the internets is to be believed the dedicated pack heater in the S/X only outputs 6KW of heat, whereas the Model 3 motors can supposedly produce ~5KW of heat. Realistically it takes a lot of heat to warm up ~1000 pounds of battery quickly. It is why Bjorn said it was better/faster to hammer the throttle than it was to wait on the battery heater to get higher supercharging rates.
I had not seen any references that high. Care to supply us an internets for that?If the internets is to be believed the dedicated pack heater in the S/X only outputs 6 kW of heat, whereas the Model 3 motors can supposedly produce ~5 kW of heat.
I had also been wondering about the effectiveness of how far it has to transport the heat. So given some amount of kW it is consuming to generate that heat in the motor, it then has to pass it along some kind of transfer medium to run to and through the battery pack, so I wonder how much heat is lost along the way moving it versus the S and X I think having that heater inside the battery pack, so with probably less transport loss.From some reading around the Model S and X forums, it seems that the pack heater pulls about 5 kW in operation. The Model 3 is supposedly capable of 4 kW but I've only seen 2.5 kW at 10F. Perhaps it ramps up to higher power in colder temperatures.
@Big Earl was right. The numbers came from TMC. Does the API accurately report the battery heating for the 3 when that message appears?I had not seen any references that high. Care to supply us an internets for that?
All right--I'll be fine if I'm wrong on that. That's why I was taught to use weasel words, like "I don't think" "I'm skeptical of" and "I'm not sure if". It leaves room to be corrected.@Big Earl was right. The numbers came from TMC. Does the API accurately report the battery heating for the 3 when that message appears?
Another data point. Low 30’s here in Michigan. I had driven maybe 15 miles doing a few errands and stopped at the grocery store whcih happens to have a SC. They were pretty empty so I hooked up and only got 20kw from 65-80%. I still had Regen dots even after the SC. The car had sat in my unheated garage for 4 days with outside temps in the 20’s. I did preheat and charge a bit before the errands but still only had maybe half or a little less of Regen available Chalked it up to cold weather.
Still happy
Much better than "waste" my time.That means "waste power to heat it to 80 degrees which is the optimal min temp for full charging on a 3.
