Solar panels hampering firefighting efforts
Discussion in 'Energy, Environment, and Policy' started by gvillager, Sep 3, 2013.
  1. gvillager
    gvillager Member
    PA
    http://www.nbcphiladelphia.com/news/local/Solar-Panels-Growing-Hazard-for-Firefighters-222085811.html
    This is something I never considered. Any thoughts on how we can prevent this sort of thing from happening in the future?
  2. JPP
    JPP Active Member
    SF Bay Area, CA
    AFAIK, the panels are set up with a way to sever/disconnect strings of panels to de-energize them. I assume that emergency responders have training on this. I know that my system has special red labels on key conduits and disconnects.
  3. jerry33
    Texas
    A fire detection system that shuts down the solar panels. Also, it's possible that the firefighters didn't have the training required.
  4. Kaivball
    Kaivball Member
    Kalifornia
    My house has a huge shut off switch on the outside, just for this kind of thing.
    Surprised that there wasn't one or maybe the fire fighters didn't see it.
  5. woof
    woof Model X 75D Blue, 6 seats
  6. rlang59
    rlang59 Member
    US
    Even if you cut the power from the ground if you are not using micro inverters at the panels there is still a lot of power up there. Most of these big installs have string inverters and I assume that is what this building had. If that was the case then the roof would have been live.
  7. mknox
    mknox Well-Known Member
    Toronto, ON
    This is a huge issue not only for firefighters but for utility personnel as well. The "anti-islanding" systems can fail, and as has been previously mentioned, a disconnect at ground level does nothing for the power being generated "upstream" of that switch (i.e. on the roof).
    There are blankets and black sprays that can be applied to the solar panels to block the sun's rays.
