Up here in the frigid north, the snow-clearing ability of this proposal is intriguing. Solar sidewalks, anyone?
That is where I think it could be of use. Is it powered from the grid if there isn't enough sun?
The concept assumes a very stable roadbed. What about frost heaves? It's unlikely that the modules would be able to conform to seasonal bumps in the road. This seems like a warm-climate-only solution.
Since they're generating heat to melt snow so that it doesn't build up on the surface, the ground below will not freeze and so no heaves will occur? (Speculation on my part.)
A mall here in New Hampshire would be better off with a solar roadway parking lot versus solar canopies. You put solar canopies up and, all of a sudden, the front-end loaders that do the bulk snow removal can't operate. *IF* the solar roadway melts it in the first place. you can consider the cost of that electricity versus the cost of plowing.
Melting the snow on top of the roads with the energy generated is impossible.
Massachusetts can currently handle about 14 GW on its grid, so melting snow on all the roads would require something like 10 times the current generation capacity of the state.
Well, they are proposing to set up an entire new grid under the earth. Which is possible, but I think they underestimate just how difficult high voltages and currents become to handle. You can't really transfer AC through cables for long distances, so it would have to be DC. Which needs very high voltages to be efficient, which needs a lot of isolation, etc. etc.
The problem with melting snow isn't how much power can be transmitted from here to there; the problem is that melting snow takes too much energy. Why would you use an order of magnitude more power than the state currently uses just to melt snow. If you can easily create that much power, put it on the grid and sell it as electricity, not melted snow. Large scale melting of snow is simply a waste of electricity. Even on a small scale, melting snow on the edge of your roof is more costly than a snow rake, but an individual can justify the convenience. It's hard to see how spending terawatt-hours of electricity to melt snow (hundreds of billions of dollars) can justify fewer snowplows (hundreds of millions of dollars).Well, they are proposing to set up an entire new grid under the earth. Which is possible, but I think they underestimate just how difficult high voltages and currents become to handle. You can't really transfer AC through cables for long distances, so it would have to be DC. Which needs very high voltages to be efficient, which needs a lot of isolation, etc. etc.
I'll have to research this more. I've heard it both ways regarding what is better for distance.
