jhm
SolarCity Corp (SCTY) Stock: Why Baird Sees 60% Upside
solarcity must have had an analyst meeting. Two key bits:
***The recent ABS was oversubscribed and had no pricing pressure. SUNE had all kinds of lack of demand issues for its yeildco spin off recently causing to lower ipo price. Not even close to the success of what Solarcity is doing with ABS, and these facts prove it. Solarcity is expected to continue with ABS very soon and often, so bodes well for continued low cost capital to keep up with current compounding growth.
***the 100MW silevo pilot plant in fremont will be operational by end of this year, which will begin output at 3X more then silevo's current Chinese pv plant. This is a welcome surprise since it will increase product while serving as a warm up to what is required to getting the buffalo factory up and running full 1GW capacity by start of 2017. Very encouraged by this news as it demonstrates how Solarcity will efficiently scale to meet its goals on time. I also see this as a potential boost in cost savings if that 100MW of product is reached within the 2016 timeframe. I wonder if this additional product is calculated into the $2.50/watt all in cost figure by 2017 ITC expiration?
These are both great points.
I like that the asset backed security was over subscribed. I'm not sure I would trust the equity markets to put a proper value on a yieldco. The bond market tends to be much more rigorous mathematically in pricing. Moreover, with Obama's promise of loan guarantees, the next time SolarCity issues an ABS it may well come with a federal guarantee. With this, the bond market may view it as the same risk of a Mortgage Backed Security. (I should ask some of my colleagues who value MBSs how much of a difference this could make.) It may well be that the mortgage GSEs Fannie Mae and Freddie Mac could get involved. The upshot here is that SolarCity and other solar financiers could provide financing at mortgage rates, under 4%.
I am also very enthusiastic about Riverbend coming online. I think it could be a big boost to the stock, but more importantly it will be great for the business.
I continue to suspect that Silevo has a 400W panel. I've been looking at the PowerHub specs trying to figure this out. For some reason, SolarCity is not being explicit about the peak watt rating of the panels. I figure that the smaller array has 50 panels (standard 65 in. by 39 in.). At 24.5% efficiency these panels would have 400W. So the whole array would be 20kW. At 3.3 kWh / kW per day, this yeilds 66 kWh / day under modest insolation assumptions. I could be wrong here, they may be assuming more sunlight than I am and lower watts per panel. But I hold out hope for 400W panels.
If Silevo is ready to mass produce 400W panels, this will be a big deal. I think only SunPower may be a competitor at this high efficiency end of the market.
PowerHub is a good illustration of how critical high efficiency panels can be. Using just moderate efficiency 320W panels in the PowerHub configuration would only generate about 53 kWh per day, 25% less power. This increases the total weight and volume per MW that must be handled in a critical mission. This logistical burden undermine the tactical value of such an energy system in say a military application. At 10,773 pounds for nominal 30 kW output, this is 360lb/kW. Using lower efficiency 320 panels would just increase the weight per kW perhaps by as much as 33%. So wherever logistics may be a critical factor, efficiency matters. I'm looking forward to SolarCity showing off what PowerHub can do. I think there's much more to it than just throwing a few panels on a shipping container.
