I just tuned in so didn't see the video of the stage landing attempt. Was there video of the touchdown?
Video froze right before it was clear if landing was a success or not.I just tuned in so didn't see the video of the stage landing attempt. Was there video of the touchdown?
Elon tweeted that booster was lost due to insufficient thrust from one of three engines. Says there is a software(!) fix planned for future landing attempts.
Agreed, I noticed that immediately and thought "there is a new view I have not seen before!" That was pretty cool.There was a very cool shot just after MECO and first stage separation. SpaceX placed a camera in the main booster pointed at the second stage. It showed the second stage firing and then boosting away. In just a few seconds the second stage was moving very quickly. That was a new visual and quite awesome.
I went back and watched the few seconds showing first stage touchdown several times. I appeared that the stage landed on the deck but there was so much smoke that I couldn't tell how stable it was.
More data for experimental landing (and Mars too, presumably).
Elon tweeted that booster was lost due to insufficient thrust from one of three engines. Says there is a fix planned for later this year to handle this case.
The only thing seen was vibration of the ASDS, followed by smoke and a landed booster with lots of fire, then a skip to even more fire and lots of black smoke, which was the last image we saw. Later we were told that the booster had been lost
Do we know they tried something that would be riskier this time than previous?Yes, and with already four retrieved boosters crowding the storage hall, it makes good sense that SpaceX tried something more difficult with more risk.
Amid the smoke and flames the first stage can be seen intermittently, standing upright with no discernible lateral movement and with the engines shut down within the outermost ring of the OCISLY deck at T+00:08:42, T+00:08:43, T+00:08:46, T+00:08:47.
So it looks like the touchdown was somewhat controlled and soft.
This is just my speculation: Once at a stand still there was little air movement around the stage, so the flames at the bottom of the stage would cause the outer booster wall and with it the tanks with the remaining fuel to get so hot that they ruptured, after which the fuel ignited causing the RUD. Or maybe the heat just caused a landing leg to collapse.
We will see.
I have the same question. I thought this mission was another payload to GTO as SpaceX has done multiple times this year.Do we know they tried something that would be riskier this time than previous?
I know there was a RUD, but I would really like to see better images of what happened, since it looked like the stage touched down upright on the deck.
