Yes it is.So then it's not really 'hiding' the top end, is it, as someone else mentioned?
You're confused because you are frequently going back and forth, interchangeably referring to two completely different things as if they are one thing.That's why I'm confused.
This is not true. Regardless of how you use a battery of what level you charge it up to, it will have some degradation over the years. All batteries do. So the total capacity of the battery will be reduced some as it ages.even if one charges a 60kWh battery to 100% daily, I'd expect to see no real degradation.
The charging limit, as controlled in software charges from the bottom up, and does not charge all the way to the top of the real capacity. But you are mistaken in thinking the reduced overall capacity is subtracted ONLY from the top end that is locked out. It is really that the degraded part is subtracted from the whole, so that is split across the physical total, and the proportion you are allowed to access.
To maybe put it in simpler terms, let's say you get three fourths of whatever is there. If you start with 100, you get 75. If it degrades so there is now 80, you get 60. If it degrades to 60, you now get 45. So it keeps the same ratio of whatever the total capacity is. It is still charging up the bottom portion of the battery and leaving the top uncharged, but because it keeps scaling like that, it effectively does look like the degradation is coming out of the usable portion.
So you were thinking of it in terms of:
1) Fills up to XX amount first
2) Then any reduced capacity would be out of the top, which wasn't being charged anyway.
But it's really:
1) Total reduced capacity is calculated
2) It fills to XX% of that.
