Nailed it!Found the answer to my question SpaceX's Starship Mk1 prototype heads to the launch pad - but why?
Yes, it was being moved and now apparently it has been placed in the newly built launch mount. Nose section hasn’t been moved yet.
Consider that they likely won't stick the landing on the first try. Consider how many Falcon 9's went kaboom before they stuck the landing. The process of landing these is a bit more complicated than landing an F9. Building 2 is a good move.
From Elon:
Hummm....What I find interesting on this pix, is what is the obvious internal volume. The craft itself is smaller than A-380, but bigger than a 747-100. However, it is obvious that the available volume is less than 1/3, and more like 1/4. As such, this will be doing great to hold 100 ppl in an all-coach airline configuration, and ZERO chance of 100 ppl to space (along with their cargo, etc).
I forgot about the F9 water landing tests. I wonder if the first Starship will be sacrificed at sea?F9 didn't really have many RUDs and the ones that did happen were one off issues. They had five or so successful test water landing after the first reentry test that failed due to roll issues. Ran out of oxygen. Sticking engine valve. Ran out of hydraulic fluid . Then there was the leg that didn't lock. A bunch of landings interspersed with the stalled hydraulic pump, FH ran out of TEA/TEB, FH2 fell over on the way back.
Falcon 9 first-stage landing tests - Wikipedia
Not if things go well. Probably start put off the coast then bting it back to the pad.I forgot about the F9 water landing tests. I wonder if the first Starship will be sacrificed at sea?
