Question about schedules in TeslaFi
If my car is plugged in a was charging and then got to 85% at lunch time. then i wanted this to start charge again to 95% at 3.30pm, in the schedules do i have to create a "Start Charge" schedule a min or so after a "Set my charge limit to 95%" schedule? Also would i also need a wake up schedule if its asleep before the change of the limit to 95%?
New to all this. Why do we need teslafi again? Does it just track charging and efficiency? Never did this in an ICE car and wondered if this is necessary. Unless it is the wife's car for location tracking. Imagine tracking every petrol station i have been and the weather on the day i filled up.
I get home and plug in and if it's low it'll charge to 55% which should be more than enough for any unexpected need later in the day.
I like that bit
But if you stop at a Supercharger (during the day) aren't you still set at 50% charge limit? (because the earlier Schedule set it to that). Of course you can override that ... but I am not sure I would always remember, and Spouse using the car would not know about that requirement ...
TeslaFi doesn't have any sort of conditional logic for its schedules ... "Charge if < 50% until 50%" would be nice (and then that could be restricted to HOME / WORK locations, and wouldn't apply to Supercharger)
Worth asking James perhaps?
I posted some Pretty Pictures in a thread recently: Winter is coming (and the following message)
TeslaFi have info on a slightly non-obvious sub domain : about.teslafi.com
I don't suppose many ICE cars transmit info back to HQ about whether the left rear seat heater is on, every minute of every day and night ... so this is probably an opportunity only available since Tesla started doing it (others may be mimicking it of course ...)
You can do "where is the car now" from the standard Tesla Phone APP. Makes having a mistress more of a challenge ...
For that I do:
Schedule #1 = Change Charge Limit (to 95%)
then #2 five minutes later (TeslaFi's max retry time ... just in case first attempts failed) Start Charge. Or Start Charge immediately after #1 and then add #3 Start Charge, 5 minutes later, - i.e. belt&braces.
If car was already (still) charging then #2 will be benign.
For example, I drop Charge Limit to 80% at start of my Off Peak. I let the car start the Off Peak charge (it will do that, regardless, if plugged in and at home. Benefit of this is that if network is down etc. the car will still, always, charge).
Then an hour before I leave in the morning I change the Charge Limit to 90% and start charging again (i.e. if it has completed 80% and stopped). benefit of this is to warm the battery before departure, to minimise loss of regen on winter mornings)
I put the Climate on 15 minutes before my normal departure time for work.
And all those are only if At Home, and Mon-Fri only.
TeslaFi Scheduler is very simple. I think it would benefit from having some more complex common use-cases - e.g. "Charge car to x% by XX:XX and start Climate X minutes before the end". To do that currently you need half a dozen tasks in the schedule
If all you want is scheduling there may be better (i.e. 3rd party) choices
Question for teslafi users: if the car's asleep and in a period when you tell teslafi to let it sleep, and you go for an impromptu drive - will teslafi record the minute-by-minute details of that drive?
For those with a passing knowledge of PHP, have a go at using the tesla api directly/yourself. I managed to get connected and retrieve my fleet of zero cars in a few minutes last night, it's really quite easy. I used this guide https://tesla-api.timdorr.com
I don't actually have a car yet but I had a go with the api's some else's. its easly enough to do single calls . The problem is if you want to log the data you need a machine running all the time so I used AWS lambda. its cloud based and serverless so you can set it to run every few minutes and log all the data and at that volume its completely free. Obviously you have to be a bit careful not to stop the car from sleeping.For those with a passing knowledge of PHP, have a go at using the tesla api directly/yourself. I managed to get connected and retrieve my fleet of zero cars in a few minutes last night, it's really quite easy. I used this guide https://tesla-api.timdorr.com
I had a think about this. Teslafi has a page about it as well .Question for teslafi users: if the car's asleep and in a period when you tell teslafi to let it sleep, and you go for an impromptu drive - will teslafi record the minute-by-minute details of that drive?
So in theory you could miss a short drive or the start of a longer one.
