Can you help me design a sealed box to fit in the trunk we'll? I don't think it's possible in anyway to make my 13.5" sub hidden and be able to put the well lid cover on
Shesmyne2 | June 9, 2013
Rear seats up (normal).
44" front to back. 19" high to parcel shelf level at the rear.
38 1/2" width front, 64" width rear.
Well: 39" wide, 20" front to rear, 10" deep.
Physical Specifications
Nominal Diameter 13.5 in / 345 mm
Overall Diameter (A) 14 in / 356 mm
Mounting Hole Diameter (B) 11.9 in / 302 mm
Bolt Hole Circle Diameter (C) 12.7 in / 323 mm
Motor Outer Diameter (D) 8.38 in / 213 mm
Mounting Depth (E) 10.5 in / 267 mm
Driver Displacement 0.21 cu ft / 5.9 L
Net Weight 52 lb / 23.6 kg
Sealed Enclosure Specifications
Wall Thickness 0.75 in / 19 mm
Front Baffle Thickness 1.0 in / 25 mm
Volume (net int.) 1.875 cu ft / 53.1 L
External Width (W) 16 in / 407 mm
External Height (H) 16 in / 407 mm
External Depth (D) 18.875 in / 479 mm
F3 37.4 Hz
Fc 40.5 Hz
Qtc 0.77
Enclosure Notes
Net volumes given above do not include the air volume displaced by the speaker (Driver Displacement). This value must be added to the net volume along with the displacement of any braces and/or ports (if applicable) to arrive at a gross internal volume. Air inside a port is not part of the effective net volume. Calculate ports as solid, not hollow objects.
* The W7’s employ a pole vent to remove heat and pressure from the inside of the speaker.This vent is located at the rear of the speaker. A minimum distance of 0.75 in (19 mm) is required between the back of the speaker and any wall of the enclosure to allow proper operation of the pole vent.
The dimensions given for the enclosure examples above take all applicable displacements into consideration
Safety Notice
It is absolutely essential that the completed subwoofer enclosure is mounted firmly to the vehicle with heavy steel bolts (0.5 in diameter) and large steel washers on both sides of the bolts. This will reduce the likelihood of occupant injury in the event of a collision or sudden deceleration.
