THIS WOULD BE SHADY
You would think, wouldn't you?
THIS WOULD BE SHADY
This is also not comparable because Intel is working around a defect in hardware. Prior to May 16 my battery was working just fine all the way to 4.2 volt charge. Charging to 90% (less than my current 100%) was a reasonable 50 minutes. The few times each year that I needed to extra 10% was available and took an extra 15 to 20 minutes to fill at a Supercharger.Tell that to Intel when they put a software "microcode" update on their CPUs to fix/workaround a hardware defect.
And what about if the part is failing because of software? You say the warranty is only for the hardware? No warranty on the software? Wow.
Well replacing the hardware won't fix the issue if the software it that causes it to do the wrong thing.
But if it is indeed a possible fire issue, they would not want to give you the choice...Tesla could have handled this much more appropriately. They could have identified a potentially dangerous condition and provided a warning on the display of such a condition. They then could say thay have a work around that will safely maintain the battery for years, but take some (10-15%) of your range. Or, you could continue using as is with the knowledge that something is going on with your battery.
Even on a day by day or charge by charge basis.
But, to just blindly apply this to cars without notification and then claim the instantaneous "degradation" is normal and further tell us after testing that our batteries are operating just fine. Without even admitting that they changed the max charge voltage which resulted in this "degradation" is flat out lying or disingenuous at best.
If indeed it is a fire issue the NHTSA should be involved to at least verify that the "fix" actually ELIMINATES the chance of fire. Otherwise a recall should be issued with this software patch as a temporary safety measure.But if it is indeed a possible fire issue, they would not want to give you the choice...
If it is indeed a fire issue then Tesla replaces the battery, the defective battery, as they are supposed to do.But if it is indeed a possible fire issue, they would not want to give you the choice...
We KNOW the fires were not while charging. We KNOW at least one was isolated to an individual module.But if it is indeed a possible fire issue, they would not want to give you the choice...
Funny how you bring Intel up when their fixes are also known to hamper performance.Tell that to Intel when they put a software "microcode" update on their CPUs to fix/workaround a hardware defect.
Why take 10 years of degradation instantly so the battery doesn't degrade on its own over the next 5 years?
I have the same experience on my 2014 p85dl. Called Tesla service line and got no real satisfaction or good explanation for the degradation. Glad I’ve found the forum!I’m seeing the same story on a 2014 P85DL.
The idea of limiting the heat and rapidity of a charge, or discharge/rapid acceleration or battery drain, to expand the battery life and limit the formation of liquid lithium metal that when it cools and forms shorts within the battery's structure or destroys the cell is smart and we need to follow all suggestions and software limits as improvements to a complex revolutionary CO2 emission free vehicle. Keep in mind you are not just driving a status symbol that you can do what you want with, but leading edge technology that will change and improve as a process that created the vehicle in the first place and significantly contributes to you stopping or augmenting the negative carbon footprint on the atmosphere from driving a car.
The Intel processor mitigation for the different security design flaws also decrease performance; before people discovered the security exploits there was also no "visible defect". That defect became apparent years later, and people were running with the vulnerability exploitable for years "without issues".This is also not comparable because Intel is working around a defect in hardware. Prior to May 16 my battery was working just fine all the way to 4.2 volt charge. Charging to 90% (less than my current 100%) was a reasonable 50 minutes. The few times each year that I needed to extra 10% was available and took an extra 15 to 20 minutes to fill at a Supercharger.
This update fixed no visible defect.
I have a small problem with this post. Dendrites are the main reason reason solid lithium batteries are not mainstream yet, but is far less of a problem in carbon based anodes with Solid Interface Layer (as are Tesla batteries), so quoting this article seems a little fake news sensational.
In fact, Jeff Dahn and colleagues and Tesla Canada, has recently released a paper with details for at NMC cell, with around 200 Wh/kg and almost no degradation over 25 years and projected to work for more than a million miles. The battery has less capacity than current Tesla cells and so is well suited for daily cycling and robo-taxis
Yet I have yet to see anyone demand either a faster processor or their money back because of Spectre or Meltdown.
