It's been referred to see the Coastal Commission:
Accela Citizen Access
Planning Review
This task is assigned to TBD
Marked as Plan Review Start on 08/17/2018 by Stacy Giles
Marked as Comment on 10/19/2018 by Liz Gonzales
Comment: The Coastal commission needs to either exempt this permit from requiring a Coastal Permit or prepare a minor amendment.
If you go to the Accela portal link Ulmo posted to see the status of this filing and either click on the "Conditions" tab or click the "View Conditions" button, at the bottom of the list it pulls up, you'll see the following:
Planning
ORIGINAL JURISDICTION
The California Coastal Commission has retained original jurisdiction over the Ventana Inn properties for issuance of discretionary permits (i.e. coastal development permits). The County will still issue any required Design Approvals and ministerial permits.
On-Going | Notice | 03/31/2016
Which means that the county is still in charge of all the building and design approvals but the California Coastal Commission has jurisdiction for the planning/zoning/development approval. Based on the location in question, I don't think it will be a problem to get a waiver/exemption from the commission. But given that they should have known this since at least April, maybe it's taking longer than expected.
