I think those adapters might have been 3D printed by some owners on their own... So not even a real factory mod, but just something 'grassroots'. I wouldn't read too much into it at this point.
I'm honestly a bit surprised Tesla hasn't done anything with the Roadster and supercharging. Even if they added the basic hardware needed to just allow the Roadster to use a supercharger even at L2 charging speeds (20kW?) that would be awesome news for Roadster owners... and I bet more would jump on at $29k. I don't think there are enough Roadsters out there to add any significant clogging of the superchargers, so this would be great PR value.
Edit:
Estimated components list:
- 4x 80A+ capable contactors
- Two normally-closed and two normally-open would be ideal
- The Model S uses two because the AC chargers are capable of ignoring the DC HV and don't need to be taken out of the loop. Unsure if the Roadster charger could handle this.
- A fuse for good measure
- New charge port and wiring
- Might be able to use existing wiring, actually, if the charge speed/amperage is limited to the same as the current wiring, and just modify it at the existing AC->DC charger
- There is already a Roadster to Model S adapter that people could get to use the new port with their existing Roadster chargers, of a Model S J1772 adapter, or a HPWC, etc etc
- New module (super small) for communicating with the supercharger, activating the bypass contactors, and controlling the pack's thermal management just like the normal AC->DC charger would
I was trying to point out how simple it actually is, although I may have made it sound more complicated.
Basically, the superchargers are more than capable of charging a Roadster pack if they were told to so with the appropriate hardware to bypass the AC charger. It literally would be, at most, a couple thousand dollars in parts even at low volume worst-case. Probably a decent amount of labor to install it all, though.
Imagine *that* positive PR value.
If you are right, please, PLEASE assemble an upgrade kit for us to install. I know we would need Tesla's cooperation... oh well.
Absolutely supercharging would be more valuable to me than added range. That's true for most of us. But I think it would be MUCH harder to implement than you suggest, far more than a couple thousand bucks in parts. In addition, it takes about 12 person-hours to replace the pack, much less open it up and replace internal parts with new brackets, bus bars, sensors, etc. High-temperature plastic injection molds are very expensive for such a small volume run. Existing wiring would only allow about 18kW max. It would take a considerable effort to get more than that. What would we get that we don't have now? One or two kW higher charging rate? At that rate I don't think you'd get enough takers to bring the parts cost down to $2 - 4,000 dollars.
Having said that, you've taken on some impressive projects and completed them with less effort than I would have expected. Maybe you're right? Believe me, I would LOVE to see you try, and succeed. Even if you just made a kit for us to install, a lot of us would buy it.
Supercharging can be done on a 2.0/2.5 without much hardware modification (i.e. no need to remove PEM/ESS).
A firmware update, a few holes in the trunk, and some trunk space to place a model S plug and HV relays.
I would be able to do all the modification/prototype myself if Tesla was willing to give me access to the firmware source code.
If you are going to be supercharging at only 30kW, I can see why Tesla would not want to bother with that. It simply won't be a good use of the power capabilities of the superchargers. Much better to install more HPWCs.
To clarify, I'm talking about the simpler modification that they are talking about that uses minimal changes. I'm sure by replacing enough parts, Tesla can get it significantly higher, but then the cost becomes an issue.Limiting factor is C rating of cells, HV cables in side the ESS, and cables from the ESS to PEM. Those cables handle burst of >600 Amps so I'm thinking much higher.. I need to go through my notes to verify what size of HV cabling they used.
The number of Roadsters is so small that I don't think it would be an issue. The advantage is that the Superchagers are along routes you might want to travel and spaced apart that the Roadster 3.0 could easily reach.
Oh well now we're talking about supercharging again :biggrin:
How hard would it be to build a charger for 3 phase charging instead of 1 phase? Here in Europe we have 3 x 230V @ 63A so that would mean 150 mi/hr of charging. Old pack full in 1h15; new pack full in less than 2h. That is already "supercharging" to me..
Much more difficult, than adding a direct hook into the DC side and having the 3 phase chargers external in some form of Rapid charger (CHAdeMO/Supercharger/CCS) Especially when those are already deployed and proven.Oh well now we're talking about supercharging again :biggrin:
Cynically I think that's the idea...but it doesn't taste like candy at that price so the tempation to jump on it is close to non-existant.
...I don't believe the battery pack itself needs to be opened at all for this. The Roadster still has an AC charger that isn't part of the pack that has access to the HV DC connection to the pack. Basically would just need access to this spot (the PEM), and the charge port. No opening of the pack would be required I believe. Edit: Looking closer at some photos it appears the HV cabling is pretty accessible.
