chickensevil
I'm assuming this one is now under construction based on the Hawthorne map. Can anyone check?
I drove by today, and I didn't see anything that would indicate they had blocked off anywhere or otherwise signs of progress.
You can see from this picture it is a rather large parking lot. I only drove around the outside which is the most likely areas they would target. So if for some reason they put it up closer to the building it will be easier to miss. As stated before, I believe the best places are going to be to the immediate south (in the photo that open lot in the middle is a likely spot since even today when it was REALLY busy, that whole lot is mostly clear.) and then to the immediate north.
