Supercharging Max
What's the max charge you guys have seen so far? I have "Raven" P100D and was surprised to see this:
I have a June 2017 s100D and can get 130-140kw At 10% SOC for a couple mins before slowly dropping to 116kw which stays till about 50%. It looks like older 100kwh model S and X can charger faster in upgraded v2 but not for very long. It is still a plus.
For the newer raven S and X, how long does it stay at 140kw for?
Sorry, I mis-typed.
What is the max rate I can expect on our 2015 Model S P85DL at 15% SoC ("State of Charge") ?
Oh, OK. Well, I have a 2014 S85, so it's generally the same battery, and those old 85s had a nearly linear tapering curve that follows this kind of rule of thumb:
SOC% + kW = 125 (plus or minus 5-ish)
So you can say 15% + kW = 125 and you'll probably be about 110kW at that point.
This is on a P90D, but close enough I suppose.
Great! Thanks!
Our 2015 Model S P85DL running version 2019.16.2 has been to a couple of busy "non-urban" Superchargers in SoCal recently and never got > 105 kW even at low SoC... but it also never got "unpaired" Supercharging either. Hoping to find a 150 kW capable Supercharger that isn't busy / paired to see if the lates software updates will get ~ 125 kW, especially with the Supercharger being the destination in our navigation for > 30 minutes.
The 90 batteries had a noticeably different Supercharging profile than the 85 ones. One of the odd differences was very restricted charging speed in the single digit percentages. With the 85s, it was always faster the lower the battery was, but the 90s stayed really low speed up until about 9-10% and then they would take off. And they kept up a higher rate than the 85s until about that 50-60% level or so and were above that 125 rule of thumb.
