Supercharging rate data
Discussion in 'Model S: Battery & Charging' started by thekomet, Jan 4, 2015.
  1. thekomet
    thekomet Member
    AZ
    I wanted to ensure that my car would work with the supercharger network. I have read that some people could not use the network despite paying for access. I am traveling to Los Angeles this month so it was a good excuse to take a road trip and gather some data. I did not use any climate control, but did have the seat heater set at level 2. I was the only car there when I arrived at the Casa Grande supercharger, but was joined by another Model S about 10 minutes into charging. The other Tesla was metallic brown and I was surprised how much I liked the color! No change in charging rate when the other car started charging.
    Rated miles left upon arrival: 87
    Rated miles kW/hr delivered Volts/amps
    6:44am: 87 102 369/275
    6:50am: 120 86
    6:55am: 140 74
    7:00am: 156 64
    7:05am: 172 56
    7:10am: 186 50
    7:14am: 196 46 394/116
    109 miles added in 30 minutes. Not bad, but not quite what the Tesla website indicates. Certainly enough to get you to the next supercharger though
  2. jerry33
    Texas
    1. Do you have an A battery? A batteries are limited in the amount of charge.
    2. As the battery fills, the charging rate goes down. Starting at 87 doesn't give the same rate as starting at 50.
  3. markb1
    markb1 Active Member
    San Diego, CA
    You need to start at a lower SoC to achieve the fastest rate.
  4. patrick40363
    patrick40363 Member
    Cali
    Please explain the lower Soc.
  5. markb1
    San Diego, CA
    SoC mean "state of charge". The lower the SoC, the higher the charge rate (kilowatts) the battery can accommodate.
    See the graph halfway down the page here: Supercharger | Tesla Motors
    Notice the state of charge tapers as it approaches 100%. Tesla's "half a charge is as little as 20 minutes" claim is based on starting at 0% (or as near to 0% as the car will let you get). The top 50% of the battery takes substantially longer. (And the top 10% is very slow!) You charged somewhere in the middle, so it was still pretty fast, but not optimally fast.
    So, to optimize charge time, you should only charge as much as you need, so you arrive at the next supercharger nearly empty. Of course, it would be unwise to not leave a buffer, I don't recommend taking this to the extreme.
  6. thekomet
    thekomet Member
    AZ
    The car is a P85D so I believe it is an E battery but I need to confirm. You are correct that the higher the SoC the lower the charge rate. I'm posing this just as an example of what one can expect.
  7. patrick40363
    patrick40363 Member
    Cali
    Thanks.
  8. jerry33
    Texas
    For sure, the P85D won't have a A battery, I missed that in the original post.
  9. tliving
    tliving Member
    New England, USA
    Temperature of the battery and the starting level of charge are the main factors. Practically i've found it impossible to get the charge I need in less than 30 minutes and sometimes up to 45 especially if I need extra range or things are cool.
