Given the integration of the battery into the Model S chassis, I don't think this is doable without a complete redesign. You can't remove the chassis from a car as it is the skeleton that holds everything together.
Why can't it just be as simple as swap one for another? The battery I currently have charges to a certain level and the one that it is swapped for will charge to that level or better.
Maybe Elon intends to create a distributed utility, supplied by solar power and others. Assuming that there are battery storage facilities (basically batteries of batteries) with N batteries to supply a buffer for solar generated power with the ability to swap out up to N batteries of customers, which are actually returned after a long distance trip. Then that would actually achieve two goals in one fell swoop while reducing required resources to a minimum, or rather utilizing available resources to their maximum. Plus, the customer can feel good thinking "My battery is doing something good while I'm away". Which psychologically further increases the bond with green tech, IMHO. What do you think?
Put simply because owners can swap their pack into the network, it's entirely possible that an entire station's packs are all owner packs of unknown condition.
Battery swapping is coming.
I had the same notion, posted it upthread but didn't get any traction from the engineers and other smart thinkers here... I wonder if its feasible or whether the necessary capacity is even in the right order of magnitude to make sense for utility rate arbitrage/energy storage on the one hand and swapping on the other.
It feels like an elegant and novel implementation to me, if the numbers are in the right universe. Certainly Musk is well positioned to envision and execute something like this...
Another question popping up: How would a swapping facility, as modeled above, fit into the furthering of battery capacity to, say, threefold over the course of the next years with Li-air? Would swapping actually be necessary, assuming a threefold increase in charging speed (or better) ? Maybe the swapper becomes a simple general means of reducing recharging overhead and waiting time?
Yes, you can log the information on memory in the pack, but that information can also be modified (there's probably no law similar to anti-odometer fraud to protect battery packs). On the other hand, there's no way to cheat fully charging the pack (as you can monitor the amount of energy going in and the SOC). To be extra safe, if you do a full cycle it'll tell you how much you can get out too.Wouldn't it be logical that the pack itself knows it's own condition?
Car rental and battery rental is not directly comparable. For one, batteries can be stacked and it takes about 10 batteries to take up the volume of a car (plus you can stack even higher).Image a car rental lot where the renter is always dropping off their existing car, which takes up a space and can't be rented out. Not good.
