drsnooker
My SSD is formatted to FAT32 and was working fine, it just does not work with this USB hub essentially making the unit useless
Not sure. Had the same issue. Scratching didn't solve it at first. Took it apart, put it back together, connected the Taptes to a PC using a little hub. Then plugged in a thumbdrive to check if that worked. Then the SSD. They are just data thru ports, So only one of the back usb plugs, is connected to one of the front/internal data ports.
Good luck, but yeah QA for the taptes should be improved. But you get what you pay for!
