Precisely. I think it’s Lithium Iron Phosphate (LiFePO4) on the non-traction, low voltage battery, as opposed to lithium ion.
They are quite different in character.
Tesla no longer use Li-Ion cells in their large stationary energy products (Megapacks). They transitioned those to LFP around the same time.
I suspect some confusion between Iron and Ion.Just for clarity LFP batteries are lithium ion batteries. You don't have either LFP OR lithium ion. I know what you mean (and I'm sure you also know what you mean) but I see confusion arising!
They both fall under the 'family' of lithium batteries, but they are different.Just for clarity LFP batteries are lithium ion batteries. You don't have either LFP OR lithium ion. I know what you mean (and I'm sure you also know what you mean) but I see confusion arising!
LiFePo4 vs. Lithium-Ion Batteries - How to Decide Which One You Need | Eco Tree Lithium
High-capacity batteries are highly sought after nowadays, for a wide range of applications. These batteries serve the purpose of recreational batteries,ecotreelithium.co.uk
Your’re hard work some days. OK what is the difference then?Well, obviously! But the difference is not to do with one being lithium ion and the other not being lithium ion ... they are both types of lithium ion batteries ... despite the misleading article titles ... the article even states "For one thing, both of these batteries rely on the movement of lithium ions to generate current." That is the definition of a lithium ion battery. The difference between the battery types is not to do with them being lithium ion batteries or not.
The differences are explained in the very article you quoted! The only thing I have issue with is only referring to NCA or NCM battery chemistries as "Lithium ion" when LiFePo4 (also titled LFP) is also "Lithium ion". We could say one type of battery is NCA and one is LFP but it is incorrect to say one is lithium ion and the other LFP ... because they are both lithium ion.Your’re hard work some days. OK what is the difference then?
OK I see where you're coming from. I've always simply called the original cobalt or manganese-based chemistries "Li-Ion"The differences are explained in the very article you quoted! The only thing I have issue with is only referring to NCA or NCM battery chemistries as "Lithium ion" when LiFePo4 (also titled LFP) is also "Lithium ion". We could say one type of battery is NCA and one is LFP but it is incorrect to say one is lithium ion and the other LFP ... because they are both lithium ion.
EDIT: Analogy ... petrol engines and diesel engines ... both are internal combustion engines. If someone is describing the two sorts of engine it would be odd to describe one as an internal combustion engine and the other as a diesel engine. Someone is bound to then say ... but they're both internal combustion engines!
Yeah the LFP type batteries I'm familiar with for bikes (even on my Porker) are "nominal" 12V batteries but the actual working voltage range is up to around 14 volts (no load) when they're fully charged. At 12 volts its basically near enough deadJust like a 12v battery is actually more than 12v (12.8)at its peak a li-ion cell tends to be 3.7v but about 4.2v when fully charged hence we are either talking 14.8 or 16.8v... its a bit like what is the actuall cc in your ice engine as in a 1.2 won't be a 1200cc kind of thing... This is what im thinking.... just probe it with a multimeter...
I see you have changed your post a bit... you actually made google this as to double check lolYeah the LFP type batteries I'm familiar with for bikes (even on my Porker) are "nominal" 12V batteries but the actual working voltage range is up to around 13.6 volts when they're fully charged. At 12 volts its basically near enough dead![]()
Yeah actually I’ve got a generic voltage / load table for lithium in my notes…which is quite handy. I looked at the loaded figure first….I see you have changed your post a bit... you actually made google this as to double check lol
A lead acid battery wil not stay at this. 13.8 or even 14v is what they need to charge, once charge they will settle at about 12.8... as for cracking 12v should be fine if the battery is healthy but at 10+ to 11v rounded, you might want to pray a bit lol
3.7 Lion cells will gladly stay 4.2 for days once fully charged but on the case your pictures, the one that says 12v I would say that it will be a fair bit higher than that as I dont know of any combination of cells that would come close but above.
Its all good... most people cant spellAs you can see I like editing my posts. A bad habit.![]()
Thank God someone has brought it back on piste. Thank you@CnixonHave not been through whole thread and its gone off piste now. But I do like the Skoda Enyak Coupé VRS especially in that Lime Green.
I dont think the grid can function on large numbers of EV it will just implode and the grid wont be able to cope and suddenly they will impose more tarriffs on electricity.
