Tesla Announces Recall Of Almost 2,800 Vehicles
The issue is that a part of the front suspension can come loose and separate from the vehicle's subframe.
insideevs.com
I just read the article this morning. I do not know, hopefully more info will be available soon.Can mobile service handle this?
That's very informative, thank you!Apparently there's a bolt that sometimes takes a few attempts to tighten, and retrying can cause another bolt to come loose. The torque wrench logs all these retries so that's why it's such a small number of affected cars.
I think it must be the ball joint which requires a torx in the center while the nut is tightened. I'm not sure why this requires multiple attempts but perhaps the torx driver is difficult to position and can sometimes end up getting torqued the wrong way? It sounds like they've since switched to a single tool that holds the torx while tightening the nut to eliminate errors.
It's not the ball joint that's the subject of this recall, it's the two bolts attaching the left end of that arm to the chassis.Apparently there's a bolt that sometimes takes a few attempts to tighten, and retrying can cause another bolt to come loose. The torque wrench logs all these retries so that's why it's such a small number of affected cars.
Very good point, even a mechanical klutz like me knows this and I follow this automatically.That’s just bad engineering practice. When fitting a part which is secured by more than one bolt, all bolts should be engaged loosely into their relevant threads, before torquing them all evenly. Fitting and torquing one bolt first is a schoolboy error!
