Seems that they put this together to show the best use-case for sentry mode. Not sure how well it's going to work when thieves approach quickly from the side of the car for a fast smash & grab but I sure hope it helps.
The side camera will pick them up.Seems that they put this together to show the best use-case for sentry mode. Not sure how well it's going to work when thieves approach quickly from the side of the car for a fast smash & grab but I sure hope it helps.
Hmmm, isn't that known outside the Tesla bubble as a "car alarm".
A cookie monster doing that on my 1998 Honda Accord would set off the alarm with the same affect.
How many of those things does your1998 Honda Accord do?
Tesla has a frunk that the thief can't get to.Well, the Honda can't record the video of the thief stealing your laptop from the trunk or play music.
However, the Honda will prevent the thief from getting into the trunk in the first place...
Accord's have a keylock on the fold down rear seats. Something Tesla should have thought of?
Would you rather have your laptop or the video of it being stolen?
Can't you just pop-off the tow hook cover, attach a 12V battery to the leads and open the frunk?Tesla has a frunk that the thief can't get to.
No, I think that's either the Model S or X, but similarly on a Model 3 you attach a 12V battery to the two leads and the trunk opens up just the same. On the Model S and X, the car alarm will go off if you pull these straps.I can open your frunk in under a minute with a pocket knife...
The Model 3 requires a 12v battery source, and it only works if the 12v battery in the car is dead.I can open your frunk in under a minute with with little more than pocket knife...
This is correct, the 12V battery system has to be disabled for this trick to work.
This is much more difficult than breaking in to an Accord. If someone is willing to go through the trouble they can have the junk in my frunk.
This guy had his 12v connected and able to pop the hood with a 9v battery.
Has this been patched?
Maybe an old thread, however another TMC member tested and was still able to open the frunk even though the 12v was NOT dead.
This is much more difficult than picking the lock to the Accord. If someone is willing to go through the trouble they can have the junk in my frunk.
You mentioned the 1998 Honda Accord. That was one of the easiest cars to break into.I have to respectfully disagree. Have you tried picking a car lock lately?
Unless you're a master lock picker; popping off a cover and applying a 9v battery to two contacts or pulling two straps seems quite a bit easier...
(and your video example still doesn't get you inside the trunk of the Honda)
Most cars have a trunk latch on the driver's side, so once you're inside the cabin, it's easy to pull the latch and pop the trunk...
