using an extremely rough estimate, it's around 5.5 million sq ft or roughly 511,000 sq meters roof so farI can see many solar panels, plus many storage batteries helping to address power factors and load shifting. All those wonderful solar things.
But...can the roof top array ever produce the power needed for the entire factory? I can see it taking a bite out of it, but I think the 4 floor factory can be consuming much more juice than can be collected on the roof.
Wont they still need to put up some wind turbines on the nearby hills and gather power from more surfaces than just this large roof?
OK - full collection of all sunlight on this one roof is a big number. 100 million kWh/yr +. Any rough guess as to how many kWh/yr the factory needs?using an extremely rough estimate, it's around 5.5 million sq ft or roughly 511,000 sq meters roof so far
New aerial photos appear to show just how massive Tesla's Gigafactory is
sunlight is ~1kw/sq meter, efficiency is 16-20%, hours sunlight usable per day is around 5.5 or ~2,000/year
So, 511,000 x (160 -200watts) x 2,000 = between ~165 million kWh to 204 million kWh/yr
double that or more w/more roof, increase a bit if PV efficiency goes up
rough numbers tho, ok
I believe the original concept drawings for the factory showed wind turbines also. Don't know if these are still planned.I can see many solar panels, plus many storage batteries helping to address power factors and load shifting. All those wonderful solar things.
Gigafactory 1 - WikipediaI believe the original concept drawings for the factory showed wind turbines also. Don't know if these are still planned.
And this is energy shipped out, which does not count the energy to produce the batteries.Well at a goal of 150 GWh of storage a year, if the cells leave the factory at 80% SOC, that is ~120 million kWh/yr ...
So- 300 MW to produce the batteries. Help me with units...is 100 million kWh/yr + = o.1 MW? or did I miss the million multiplier? If my math is not corrupt - there is no way for the solar array to offset production power.Gigafactory 1 - Wikipedia
Tesla intends to power the structure through a combination of on-site solar, wind and geo-thermal sources.[10]
and
In 2014 Navigant estimated 100 MW electricity delivery which could be supplied (on average) by nearby wind turbines and roof solar panels,[83] whereas a former Tesla logistics manager in 2016 estimated 300 MW to produce 35 GWh of battery capacity per year.[84]
"100 million k" has been bothering me ever since I started reading it 5 minutes ago.So- 300 MW to produce the batteries. Help me with units...is 100 million kWh/yr + = o.1 MW? or did I miss the million multiplier? If my math is not corrupt - there is no way for the solar array to offset production power.
1) Size of present roof is appx 5.5 million sq feet or 511,000 sq meters
2) Assume ~100% of roof covered with high end premium cells, non tracking fixed
3) Standard sunlight is 1,000 watts per sq meter or 1 kilowatt/sq m
4) 511,000 kilowatts incident sunlight, average per year
5) 511,000 x 0.21 x 1.105 (adjust for PV watts default of 19%_ = 118,606 kilowatt array
6) Using PVwatts with Latitude, 39.53, Longitude: -119.74, Sparks Nevada, USA PVWatts Calculator
7) (Using 21% efficient cells (as 23% is presently max) Solar Cells
8) 192,335,920 kWh/Year (figure 1)
9) If you tweak things, and 23% efficient instead of 21%, you can up it to 230,000,000 kWh/year
10) If you tweak things again and have 23% efficient and single axis tracking on the roof you can get over 310,000,000 kWh/year (figure 2)
11) Figure 1, fixed array, 21% efficient
View attachment 336227Figure 2
remember, if you use PV watts and premium cells, it defaults to 19% efficiency, standard cells deaults to 16% and thin film/amorphous ~10%. if you are using 21% efficient you multiply by 1.105, etc. If you look at pictures of roof, they look like they will tilt. incident light goes by the cosign of the angle, preferably at 90 degrees incidentCool,
If I split the array into east leaning and west leaning (75 degree) halves (59,303 kW each), I get ~122,000,000 kWh/year (63+59).
Unlikely that they tilt since the panels are slightly angled towards each other. If they actively tilted they would all face the same direction and track the sun as it moves.
Dummy it down for me.. Seems like a full roof can produce 200-300 million kW in a year. And that it takes 300 MW [million kW] to produce 35 GW of batteries (no time unit, but presume annual). Now I am just missing the intended/actual battery production. Are they making 35 GW? or is this an ultimate potential?
So the Q? still is => can a full roof supply enough power to run the plant?
I'll guess at least 600 GWh, perhaps more if the original estimate included a lot of wind energy that has a higher capacity factor than PV. Wind easily produces 3 kWh a year per rated watt, so a 100% wind source of 300 MW = 900 GWh annually.So- 300 MW to produce the batteries. Help me with units..
