According to what I've ready, our Bolt tops out at a 100kW charge rate. To date, that's been all theory. There are no chargers on which we can test it.Which version of the Bolt is going to take the full 150kW charge?
Interesting, when I went to look there was a line just to test drive them, it's was all everyone was at the dealership for, other than a young kid checking our a camero. I guess things have changed.With an asterisk. My local Chevy dealer has 1, the dealer 60 miles one way has 1 and the dealer 60 miles the other way has 2.
Also Bolts can stop at tesla chargers with the teslatap right?
I stand corrected. Thanks!It has been tested in Europe and the USA. 55 kW - 56 kW is the limit. In practice, this cuts charging time between 0% and 50% by about a third. After that the power is tapered to below 50 kW.
When was that?Interesting, when I went to look there was a line just to test drive them, it's was all everyone was at the dealership for, other than a young kid checking our a camero. I guess things have changed.
The AC Destination chargers. Assuming the property owner is cool with it, and I'm not sure why they wouldn't be, as they aren't controlled by Tesla at all.Also Bolts can stop at tesla chargers with the teslatap right?
Clearly Tesla will have a substantially better charging network that is 3-4 years ahead of the CCS network for a number of years to come. However, it will soon be easy to drive a Bolt EV coast to coast at Electrify America locations.
Each location has a minimum of 4 fully independent chargers typically with redundant cables capable of charging at 150 kW or more (limited by the car’s capability). In comparison, each Supercharger space has a single cable and shares its charger hardware with an adjacent space.
The paddle just temporarily increases the baseline max regen level which can then be modulated through the accelerator pedal.I can press or release the pedal to different degrees, causing the braking force to be stronger or weaker. I apologize for any ambiguity.
The brake pedal? Not the paddle, right?
You are describing coming slowly to a stop sub-5 mph because that’s what the Model 3 is presently capable of doing. That’s very different from how the Bolt comes to a stop without the break pedal sub-5 mph.Yes, I can. Do it all the time. But then I’ve practiced using minimal braking on ICEs over the years as well.
It’s trivial today because it just takes a credit card or ApplePay/AndroidPay. They are working on having a smartphone app and that may allow for subscription plans etc.Also, do we know how easy it is to figure out the payment scheme of the EA charging system? In my 3 years driving a Leaf with DC capability it was a constant hassle to figure out if I had the correct payment card/membership set up ahead of time.
The point is that a 4 space Supercharger setup has 1 cable at each space and one charger failing will take down 2 spaces.Which version of the Bolt is going to take the full 150kW charge? And anyone using a Supercharger knows the 1A-1B pedestal numbering system (no, not always adjacent) to easily figure out where to plug in for max charge rate.
I thought those were supposed to be dual charging terminals, like an Tesla A/B pair where you split the 350kW? The 350kW nominal for the gear is based on roughly 940v battery that you're charging, otherwise it's really a 400v system that can do 150kW on 2 channels.An Electrify America 4 space setup has 3 spaces with 2 identical cables each and one space with a CCS cable and a CHAdeMO cable. Each space has its own dedicated charger.
That was the root of my question, if he didn't realize the paddle is binary. Turns out he was talking about the accelerator pedal not realizing Teslas are like this as well in that you control the regen through a band? The paddle isn't that much on top of "L" anyway, it's a bunch of finicky to go through that + paddle to reach into a narrow gap. If I'm feeling the need to go to that gap I'm overshooting to start with, and need it all....and if I don't pulse modulating with the paddle gets it done.The paddle just temporarily increases the baseline max regen level which can then be modulated through the accelerator pedal.
They also have dual-headed CCS-only chargers. I suspect in the end they will heavily favor CCS and only have one or two Chademo connectors per location. The main reason why they have two cables per charger is to allow cars with different charge port placement to use them while keeping the cables short and their weight manageable. Tesla gets away with just one cable because the charge port on Teslas is always in the rear left corner, so they can align the units with the parking bays accordingly.Electrify America locations will not have redundant charge cables on each charger. Instead, each charger will have one CCS connector and one CHAdeMO connector. If one is damaged, you won't be able to use the other one unless your vehicle has both connectors (none do).
The highway locations in the first deployment phase are supposed to have up to 10 charge units.Most EA stations will be able to charge four vehicles simultaneously
I think the problem is that the cables are thick, heavy and unwieldy (especially the water-cooled cables that are used on the higher power chargers). You can't just snake them around the car like the cables on a Level 2 charger.Interesting. I wasn't aware of the dual cord configuration plan, as I was under the impression that they were to be supporting both standards equally. I'm not really sure how having a cable on the left and a cable on the right is a better value than a longer cable that can reach both sides (perhaps 3 feet longer) and a cable of a different type. *shrug*
You're right, trying to drive a Model 3 like it actually has one foot driving is stupid. I tried this as well. All it does is irritate the people behind you and possibly get you rear ended. As I said above, I think Tesla could implement one foot driving with a software update that makes the regen much more aggressive at low speeds so it actually stops the car then puts the "Hold" on.I actually timed waiting for my Tesla to go from 5MPH to 0MPH by regenerative braking alone. It took 10 seconds. To me, that's a long time to coast up to a stop sign. Especially block after block. But, you know, if it works for you, it works.
Different tests can give different results. Would you not put your family in a Tesla Model S due to its "average" result in the IIHS small overlap crash test? We don't even know how the Model 3 will perform in that same test. It may do no better than the Model S, which did worse than the Bolt.From NHTSA tests, Bolt only has 4 star ratings for front passenger side for frontal crash, and 4 stars for rear passenger for side crash.
Even if they had better colors, the car looks like an upside down bathtub. It doesn’t matter what color it is.
My problem with the Bolt, i3, Leaf, almost every other electric or hybrid electric vehicle out there including the beloved Prius - why must they look like they're mocking the people that want electric? It's like the car companies are sitting there thinking the market for electric vehicles is made of a bunch of kale-eating hippies that want their cars to look like futuristic bubbles with headlights, so let's make fun of them by designing a silly-looking clown car with whimsical and stupid design details.
I feel like Tesla is the only car company that takes buyers of electric vehicles seriously by designing mature and sophisticated vehicles - they just look like decent-looking, simple and minimalistic cars without the silly-factor (though the FWD on the X is a different kind of silly!). The fact that most of these "affordable" electric vehicles look like bad jokes is a big part of what kept my family from going electric earlier.
I don't get this mocking of the Bolt's appearance. Sure it's far from a sexy sports car looks. But it looks like a normal hatchback/wagon to me. Not weird like the Leaf or Prius or i3. The Tesla X, on the other hand, looks like an egg, Lol. That's what my non-EV friends said when the X was first released.
The Coming Soon list only includes locations that are currently under active development (permits, construction).I'm in Houston, 3rd largest metro in the country. There isn't L3 support to get the Bolt to Dallas. EA website's Coming Soon list doesn't change that state of affairs.
My understanding from discussion with a GM media representative is that the patches did not actually improve the battery cell failure detection reported back through OnStar. The point of the OnStar reporting is to allow GM to detect failing cells and notify the owner for a battery pack replacement under warranty.The system checking for the failure is improved (so supplant their OnStar hack for the problem ).
I’ve taken both US-101 and CA-99. Leaving from San Francisco adds about 50 miles of distance.Did you? I'm impressed. We live in the South Bay and I looked at driving the Bolt to see our daughter at UC Irvine. I looked at the route we would be forced to take, the number of charging stops, and the length of those stops, and I just thought, "No way. I'm not doing that." And I think most people would feel the same way. I do admire your enterprising spirit though, make no mistake.
The phase 1 plan is being built-out over the next year. The exact ordering of the build-out is driven by various factors. There are 3 Coming Soon sites listed in California and at least 2 of them already have charging pedestals and chargers installed but are not yet open. California will have strong coverage over the next year with about 50+ highway DC locations and another 110+ community DC charging locations for total of over 500 charging spaces.Well, I do hope so. Increasing the number of electric cars out there is super important, and infrastructure is a critical problem. So far, Electrify America has had some pretty weird priorities. California is the most important EV state, and they haven't opened a single station there. The nearest one is in eastern Oregon, near the Idaho border. God knows why.
Did you lower or remove the optional false floor covering?For a trip to the airport, we can squeeze 4 suitcases (airplane overhead compartment size) into the back of a Bolt underneath the cover, with any remaining items going in people's laps.
I think there are few 277V destination chargers and I have the sense that they may not work with the Model 3.I don't know if they can handle the 277V AC ones, though?
Your understanding is incorrect. What we have seen so far is that all of the charging spaces have charging pedestals with two identical and thus redundant cables — except for one space in which one of the cables supports CHAdeMO. This is true even on the first 10-space charging location where 9 spaces have redundant cabling and only one space supports CHAdeMO and CCS.Electrify America locations will not have redundant charge cables on each charger. Instead, each charger will have one CCS connector and one CHAdeMO connector. If one is damaged, you won't be able to use the other one unless your vehicle has both connectors (none do).
This is incorrect. The CCS cables are always liquid-cooled and are inherently capable of supporting up to 500A. The CHAdeMO cable is conventional and limited to 200A because there are no liquid-cooled CHAdeMO cables and connectors available from part suppliers yet.Another consideration is the design of EA's stations. The 150 kW ones will only provide that much power on an 800 volt high voltage battery pack, as they're limited to 200 amps output. A normal 400 volt pack would only receive about 80 kW (Jag I-Pace), compared to Tesla's current maximum speed of 120 kW (or 72 kW at urban Superchargers).
No. Electrify America has chosen to give each charging space its own independent full-capability charger.I thought those were supposed to be dual charging terminals, like an Tesla A/B pair where you split the 350kW? The 350kW nominal for the gear is based on roughly 940v battery that you're charging, otherwise it's really a 400v system that can do 150kW on 2 channels.
