Puddles
*Sigh* Time to go couch shopping.
No need! Be like Elon! Get your fans to crowdsource you one!
Or sleep on the bloody factory floor. LOLNo need! Be like Elon! Get your fans to crowdsource you one!
AP is not designed for use on surface streets.AP behaves okay at 50 mph, then going into a 30 mph zone starts to weave, making me look impaired. It's going into jail until this is fixed.
I don’t think it’s as much about over reliance or blatant misuse of the system. I sympathize as I find the nags bothersome as they are seemingly unpredictable as hand torque is variable particularly when the wheel moves itself. You almost have to “pretend steer” to keep the car from throwing a fit unless you’re constantly touching other wheel buttons.Whenever I come across posts that suggest putting an object on the steering wheel I mutter and rock. I’m not opposed to circumventing the nanny, but....
What if you’re in a collision and that object is dislodged and ends up between your face and the deploying air bag?
There was a fella who espoused hanging a bag of bird shot, and I don’t think he’s ever going to forgive me for the merciless ribbing I gave him. But i can’t think of a better thing to insert into my imagery of such an event. Coins are another good one. Even an orange coming at you at 100 mph is gonna hurt.
You f_cking idiot
I could not disagree with this statement more.Autopilot changes its behavior daily.
I took some folks from the local car club for a ride. Tried to demo Auto Pilot. Tessie refused to cooperate. Stopped. Put it in Park. Got out. Got back in. Took off. Same warning: Auto Pilot disabled. I turned to my passengers, threw up my hands and said, "I don't know what I did but apparently I pissed Tessie off." They laughed. She can be stubborn.
I use AP a minimum of 1 hour on a daily basis, sometimes in bumper-to-bumper and sometimes with full speed. I have learned what it takes to keep AP happy and it is very rare that I get a warning (unless I am doing something I shouldn't, such as having both hands off the wheel - usually in bumper-to-bumper).
It's about developing the muscle memory and programming yourself to apply a slight pressure every few seconds (with a much shorter interval than the warning interval).
Software and firmware being “the same” notwithstanding, its entirely possible some cars are just more sensitive than others.I could not disagree with this statement more.
I normally have my elbow on the center armrest and just squeezing the wheel at that angle is enough to put sufficient torque on the wheel.
That may be the case, but I can't see how it can vary from day-to-day within the same car as @bpobill stated - that is the part I have serious doubts about.Software and firmware being “the same” notwithstanding, its entirely possible some cars are just more sensitive than others.
We don’t know until someone cracks the algorithms however I’ve experienced days where NoAP is next to unusable unless you’re practically “mock steering” and days where just a light constant weight toward one side or the other keeps it happy. I have no doubt the car keeps logs stored on how often it has to nag you.Almost the same: I have my left elbow on the door up against the window. And I've programmed myself to periodically put a little extra torque momentarily just to make sure.
______________________________________________
That sounds like a good plan. You'll get the hang of what is needed to keep the alarm to a minimum. It really doesn't require a lot of torque and in the beginning you'll probably over-torque and disengage the Auto Steer a time or two. But you'll get the hang of it.I've rested my hand on the bottom of the steering wheel, but I'm going to try having it around 10:00 instead. That way, the torque should continuously let the car know my hand is on the wheel.
Even if someone has the correct weight on the wheel doesn't mean they are paying attention.
Literally if you have a hand on the wheel by the vertical spoke it will be enough to show input into the system to not cause nags - as it steers it feels your pressure against the turning of the steering wheel. Waiting for the audible or red nag is almost assured to cause it to kick out eventually as your response will not be fast enough very quickly and then it will deny you for the rest of the trip. To avoid this keep your hand on the wheel by the spoke and if you see a nag just put gentle pressure against the spoke and it will go away or give one click on either thumb wheel and it will also go away. To be clear the pressure on the wheel it needs is some (not much) resistance to the steering wheel turning the wheels and does not detect your touch or "squeeze" pressure on the wheel.Well, that's the thing. I had one hand, and often two, on the wheel at all times. It was rainy, and I was paying attention. I have had to take control enough times that I do not trust AP completely. A few miles earlier, I'd watched someone merge in front of me and Nick didn't slow down much.
As I said in the OP, I don't think I missed any alerts, but who knows? There were a few times when it was flashing blue, but I purposely waited for the auditory alarm before moving the wheel. Maybe that's it.
