Yes Steve, the 6-50 adaptor I posted about worked perfectly for three consecutive nights during my late October trip.
I purchased a nema 6-50 and 5-20 adapters yesterday at the Rocklin Tesla Store. They were $45 each.
I believe I ordered one as a 'just in case' when I got my car. Let me double check. Since I don't think I will ever use it, I'm willing to part with it.
I need one of these adapters. I just got my P85 today and I want to use the oulet I was using for my Leaf. The outlet is a NEMA 6-50R and from what I am reading and learning, there is some adapter (which I think you had at one time) that works with my Tesla cable.
If you no longer have it, do you know where I might find one?
Thanks,
Robert Pack
If you can't find an official Tesla one, this one will work in conjunction with your tesla 14-50 adapter.
NEMA 6-50P to 14-50R EV Adapter, 50A, 250V | EV Adapters
OMG! The NEMA 6-50 adapter is for sale again! That's the first time in like three years it has been for sale!
Guys, I am pretty clueless with home electrics. I have just literally purchased my first new Tesla (at last) and delivery is due today. My Garage has a 6-50 adapter and I didnt realise the Tesla needed a 14-50 .
If i purchase the adapter 6-50 to 14-50 will that work ? Simply plug in the Tesla connecter cable to the adapter ?
Apologies if i sound more stupid than normal!!
If you have a 6-50 outlet, you can buy the 6-50 adapter and use it instead of the 14-50 adapter. I would also suggest you check the electrical panel to see if the 6-50 outlet has a 50 amp breaker or fuse since many 6-50 outlets aren't installed with a 50 amp outlet as they were installed for welders or other devices which aren't "continuous use". If it doesn't have 50 amps then you will need to manually set the amps that the car will use when charging. Typically on a 50 amp outlet you would be able to use 80% or 40 amps when charging. Last December, I used my brothers 6-50 outlet and found out after a couple hours that it only had fuses (yes, fuses, not a circuit breaker) and they were only rated for 40 amps. I blew the fuses and had to buy replacements and install them before I could charge with his outlet again. I manually set the car to only use 32 amps (80% of 40 amps) and didn't have any problems charging after that.Guys, I am pretty clueless with home electrics. I have just literally purchased my first new Tesla (at last) and delivery is due today. My Garage has a 6-50 adapter and I didnt realise the Tesla needed a 14-50 .
No need to apologize!
If you are *certain* you've got a 6-50 in your garage, then the 6-50 UMC adapter is what you'll need. But, I'd double-check the outlet, just to be sure.
The UMC does not actually require a 14-50, that's just one of the adapters included. As you can see in the online shop, there are a bunch available. What you'd be ordering from Tesla is not a 6-50 to 14-50 adapter. The adapter for sale should probably technically be called a UMC to 6-50, since the UMC uses a proprietary connector. However, just so you know, it is also possible to find and safely use a true 6-50 to 14-50 adapter. This kind of adapter could be a little cheaper, and might give you some more total cable length, if you need it. Tesla does not sell these.
Word of caution. As you might have learned from this thread, Tesla has a long history of being very unreliable with UMC adapter availability. So, if you see something you need (or could imagine needing in the future), I'd recommend picking them up. Personally, I have a spare for the one I use the most, the 10-30. And I'm glad I bought two, because shortly after I did it became and remains unavailable.
You should go to the box to double check. I would buy one if I were you in case Tesla runs out again. I would be surprised if the charging cable is different for the Model 3, but it might be a good idea to hold out a few weeks to be sure.Had this installed in my garage when our house was built a year ago....Can I assume it is on a 50A circuit or do I need to go to the box and make sure? Also, is this Tesla — NEMA 6-50 the adapter I need. If I buy a 3 (assuming is has a similar set up to the S, will all I need extra is that adapter?
Thanks!
No this is an incorrect and dangerous statement. The car does not know what amp circuit the UMC is plugged into. It only knows what adapter is being used. With a 6-50 adapter the car sets 40A no matter what circuit it's on, assuming it's a 50A circuit (80% of 50A), but that assumption can be incorrect. If it's a 40A circuit then drawing 40A is dangerous. It needs to be turned down manually to 32A. This is why you need to check the breaker and be sure what the circuit is.You should check the breaker and make sure. My brother has a 6-50 outlet in his garage but it was only installed on a 40 amp breaker since it was intended for use with a welder. If it is on a 50 amp circuit then the 6-50 adapter would automatically set it to the maximum of 40 amps when charging.
