It should have a 50 amp breaker for a 50 amp outlet. It seems that 6-50 outlets often only have 40 amps. I found this was also the case on my brother's garage and now I limit the rate to 32 amps when charging there.Interesting. Our paperwork says the electric car charger add on was to include a dedicated circuit for 240v 50amp NEMA 6-50 outlet.
I guess maybe the outlet is for 50amps but they don't necessarily have to provide that many at the box?
Also, how do I tell if it has its own dedicated circuit?
Can you tell what the wiring is labeled as? It might be possible to upgrade the breaker to 50 amps if you have the correct gauge wiring.
Same problem at my parents house. They have a 6-50 with a 40A breaker. I believe those are typically used for welders and that's just the "standard" for some stupid reason. I also no longer have exposed wiring to verify the gauge of the installed wires and the jackets are trimmed too close to see anything in the box or the panel.. I'll be dialing down for a while. Someday I'll be bringing a drywall saw to confirm the wiring jacket.It should have a 50 amp breaker for a 50 amp outlet. It seems that 6-50 outlets often only have 40 amps. I found this was also the case on my brother's garage and now I limit the rate to 32 amps when charging there.
Oh well. I only lose about 6 miles of charge per hour right? And would just have to remember to set the car to charge at 32A?
Correct. There is, however, a risk. The car *may* forget the current is dialed down. Either the GPS gets confused or something gets reset.
The breaker should protect the wire if it happens to be undersized.
It is just something you should double check occasionally.
And yes, 32A should be plenty to meet the needs of most normal folks for charging an EV.
Hmm. The tesla product page for the 6-50 adapter says a 50 amp circuit breaker is required.....I'm guessing this means the wiring and amperage of the existing breakers (40amp breakers) are not sufficient for the tesla charging?
Only because the default charging with that adapter is 40 amps, which is too much for the circuit. The car will charge just fine on 32 amps. Tesla is being conservative with the requirement, because (as noted up-thread) the car can sometimes "forget" that it was manually dialed down to a lower setting, and revert to the default. At 32 amps, all will be fine.Hmm. The tesla product page for the 6-50 adapter says a 50 amp circuit breaker is required.....I'm guessing this means the wiring and amperage of the existing breakers (40amp breakers) are not sufficient for the tesla charging?
You can still your Tesla with 40A breaker. You just have to make sure to dial down the charging ampere setting from inside your car down to 80% or your breaker.
That means your car got to say it's charging at the maximum of 32A.
However, your setup is not approved by electrical codes and if your car is plugged in a 6-50, it automatically thinks that the breaker is 50A and your car would automatically set its charging Ampere to 40 (80% of 50A is 40).
In so doing, your circuit might risk overloading and electrical fire.
Yes, it's been reported here several times. Which means it's happened many times more than that, as most Tesla owners are not on TMC. When it has been reported to lose the setting it's usually after a firmware update, just as other settings have been lost after firmware updates.I'm curious - has anyone experienced the geo current limit loss themselves? I charge in two locations, both with the location limiting current. And for the past 2 years, I've never seen one forgotten once. I still regularly check, just to be safe. But I'm wondering how common this phenomenon actually is.
Yes, NEC article 625 (specifically 625.14) specifies that electric car charging is always classified as a continuous load (regardless of actual charge time).I believe this is incorrect information. As I understand the code requirements (I'm not a pro), the limit is 80% if the load is continuous. (not a Tesla decision).
Thanks! I guess the best bet would be to get an electrician out to at least look at the situation and see if anything can be done to get it up to code and a bit safer.
A workaround (which could help @ChrisH as well) - order the Canadian 14-50 adapter, which automatically sets the charge rate to 32A, then buy or build a 14-50R to 6-50P adapter.I *almost* wish that Tesla made the 6-50 adapter with 32a built in limit.
No matter how pedantic, it would still be safer because the current limit would be enforced by hardware and not subject to the software limit that can be lost in a firmware update.Although, if you want to get pedantic, this setup would probably be a code violation, since Tesla says not to use extension cords, and the NEC requires you to follow the manufacturers requirements.
Clumsy wording on my part. Tesla is required to go by code ("being conservative" wasn't the right phrase), and I've been told that code doesn't allow you to get by with a programmed limit in the device (car in this case). Somebody could plug something else in without the reduced setting and cause an issue.I believe this is incorrect information. As I understand the code requirements (I'm not a pro), the limit is 80% if the load is continuous. (not a Tesla decision).
My suggestion - just get the Tesla Wall Connector and leave the Mobile Connector in the car.
