]Don't puck it up, use our custom specialty tool.
Only a exact match tool can give you the confidence in lifting your Tesla without damage.
This lift plate adapter gives you clearance both in height and keeps your floor jack away from the $45k battery pack on Tesla Model S. Just a 1/4" too far inward can damage that very expensive battery pack and leave you out of pocket.
This will only fit a Model S
Tesla requires air suspension must be set at highest setting then jack mode.
Model S without smart air suspension and 19” wheels best used with a low profile 1.5ton floor jack for clearance with a minimum height of 3-1/2” but with air suspension a 3ton floor jack can be used. Harbor Freight makes a sturdy low profile floor jack that works well for a single corner lift.
Great for just normal maintenance when removing the wheel is needed or swapping your winter tires over to summer set.
No hassle or fighting to line up the jack with the plate, easily slide the cylinders into the receiver holes on your lift plate under your vehicle and the magnetic force holds it in place then slide you floor jack under to lift.
Heavy duty 3d printed and durable rubber.
Hand made in Texas, we do not sell cheap Chinese junk.
Murphy’s Law Roadside Assistance LLC. All rights reserved.
https://murphyslawjackpadadapters.com/
Model S
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142783372420
Model X
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142628612590
Model 3
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142709055354
Tire service kit
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/142806808314
YouTube channel
https://www.youtube.com/channel/UCW3MJnAftbRQ7ScQp27aK6A
Model S
Model X
Model 3
Tire service kit
YouTube channel
