Lack of originality, lack of engineering talent…
I think Warren got it wrong.Seems there are two ways to match Tesla on efficiency. One is a decade of constant tweaking and refinement using the finest engineering. The other is to cheat…
This makes me anxious for what comes out of Texas. The 4680 cells and single casting front end should drop at least 300-500 pounds more.
Their MYP has spent over a year of being launched over and over and over...They over-emphasized that the extra quickness of the Model Y was due to it being lighter. The fact is, the Model Y just puts down more power over the run. And they kept giving the jump off the line to Mach-e to make it more even than it really was. Edmunds gave every advantage they could to the Ford and the Tesla still stomped on it. They had no choice but to call the Tesla the winner. The Model Y would have won even if they added weights to make them the same weight. I determined this by using an online HP calculator based on both the 1/4-mile ET and also the 1/4-mile top speed and the listed vehicle weights plus 200 lbs. for driver and gear.
The fact that the Model Y puts out more HP with a much smaller battery shows Tesla's technological superiority. But, yeah, shaving 300 lbs off the Model Y with 4680 structural pack and F&R castings is probably in the ballpark and will make it slightly quicker yet. About 1/4 second in the 1/4-mile.
1. EPA references efficiency directly. That mpge rating will tell us how Lucid does in efficiency. We should not jump to the conclusion that Lucid is lying to the EPA or cheating the test.
2. 134 kWh is what was drawn from the charger. Some of that might even go to run cabin climate, and definitely some is lost through charger inefficiency. 13.5% seems kind of high, but Warren’s claim of a single Model 3 test is absurdly low.
Coulombic efficiency (CE), also called faradaic efficiency or current efficiency, describes the charge efficiency by which electrons are transferred in batteries. CE is the ratio of the total charge extracted from the battery to the total charge put into the battery over a full cycle.
Li-ion has one of the highest CE ratings in rechargeable batteries. It offers an efficiency that exceeds 99 percent. This, however, is only possible when charged at a moderate current and at cool temperatures. Ultra-fast charging lowers the CE because of losses due to charge acceptance and heat, so also does a very slow charge in which self-discharge comes into play(See BU-808b: What Causes Li-ion to Die)
The coulombic efficiency of Li-ion improves with cycling. To prove this, Panasonic, E-one Moli, Sony, LG and Samsung Li-ion batteries in 18650 cell format where cycled. Some cells began with a coulombic efficiency of 99.1 percent and improved to 99.5 percent with 15 cycles. Some started at 99.5 percent and reached 99.9 percent with 30 cycles. The consistency on repeat tests was high, reflecting in Li-ion being a very stable battery system.
They should, but the only weight of the Lucid I could find, 2150kg, means that it only weighs 27 pounds less than a Model S. So something in there is very heavy.It always seemed to me Lucid had 2 big advantages:-
1) Higher voltage
2) Thinner body - reduced drag
Both of these advantages some with some trade-offs but should lead to:-
3) Reduced weight.
Here are 10 more reasons to be Thankful for TSLA this year: (are you in the top-ten?)
Jeopardy Highest Regular-Season Winnings
Happy Thanksgiving to all my American cousins.
- Ken Jennings | $2,520,700
- James Holzhauer | $2,462,216
- Matt Amodio | $574,801
- Jason Zuffranieri | $532,496
- David Madden | $430,400
- Julia Collins | $428,100
- Matt Jackson | $411,612
- Austin Rogers | $411,000
- Arthur Chu | $297,200
- Seth Wilson | $265,002
Cheers!
BBC gets a lot of funding from Billy Boi Gates foundation. As we all know, Billy Boi is $TSLAQPrimetime FUD in the UK this evening...
BBC One - Panorama, The Electric Car Revolution: Winners and Losers
How ethical is Tesla's supply chain? Darragh MacIntyre investigates.www.bbc.co.uk
What a load of uninformed rubbish. Basically blaming Tesla for all sorts... including trespassing miners being injured because they scaled Glencore's security fences! Complete hit-job saying Tesla is at the heart of all the issues with Cobalt etc.
Unbelievable that this was able to make it on to the BBC.
Shaving an additional 300-500 pounds off the Model Y is going to make it quicker regardless.They over-emphasized that the extra quickness of the Model Y was due to it being lighter. The fact is, the Model Y just puts down more power over the run. And they kept giving the jump off the line to Mach-e to make it more even than it really was. Edmunds gave every advantage they could to the Ford and the Tesla still stomped on it. They had no choice but to call the Tesla the winner. The Model Y would have won even if they added weights to make them the same weight. I determined this by using an online HP calculator based on both the 1/4-mile ET and also the 1/4-mile top speed and the listed vehicle weights plus 200 lbs. for driver and gear.
Warren is someone who said that Lucid will not start production this year. They didI think Warren got it wrong.
Ummm, what?It is entirely aside from the point as far as I’m concerned. If your car is 10% less efficient at the charging station or on the road, it amounts to the same thing.
I fully get Elon wants to be on top.Yes Rob, I get it. But what you might not get is Elon wants to be at the top. You know, the whole mission thing. #TimeWillTell
