Artful Dodger
"Neko no me"
Everything in terms of information has pointed to the Austin-Y being identical in specs.
Austin Models Y will have front castings, a new body design modified for the structural battery pack, and the first use of 4680 cells as part of their spec.
Model Y in Fremont differed primarily from Model 3 by first use of the rear casting, and a new body structure to accomodate the hatchback.
I'd argue that Fremont Y has more in common with Fremont 3 than with the Austin Y. Would you also claim that Model 3 is "identical in specs" to the Fremont Y?
Of course, several of us have discussed here for months the advantages of offering an upmarket Austin Model Y initially ie: Plaid Y @ $80K during the ramp (ie: until local 4680 production is able to replace Kato Rd. cells). Paging @TheTalkingMule
As Sandy Munro recently showed us, Models 3/Y/S all have backward- and forward-compatible castings/housing for motor inverters. Model Y Plaid doesn't need a 175 mph top speed like the current Plaid S offers (with ceramic brake upgrade), so Plaid Y may not even require carbon-wrapped rotors like P/S.
I think this all makes an upgraded-spec, higher-priced Model Y from Austin more likely.
Cheers!
